Audi Concert II to RNS-E & Bluetooth
mattyg123 Apr 30, 2012
  1. mattyg123
    mattyg123 New Member
    29
    As above, I currently have the Concert II stereo in my A3. It also has factory fitted bluetooth installed, which has been working fine in terms of reiceving calls etc. Although I don't have the ability to look up contacts, which i'm sure if my headunit is supposed or not may be the case to do?
    My question is if I upgrade to the RNS-E, will the factory fitted bluetooth continue to work seamlessly or is my current bluetooth set-up only functional with my Concert II headunit?
    Many thanks in advance for the help. :)
  2. apoc_reg
    apoc_reg Member
    66
    I'm certainly no expert matty but I think the bluetooth is seperate from the headunit so should be fine.
  3. jb0o
    jb0o North East Forum Moderator Site Sponsor Regional Rep VCDS Map User
    2,662
    116
    Will work fine with RNS-E.
  4. NHN
    29,280
    1,692
    The rns will significantly improve the BT interaction & even better with an mfsw :)
  5. Gazthesparky
    Gazthesparky Member VCDS Map User
    217
    Hi sorry for hijacking a post but I saw you have a concert 2 stereo with oem Bluetooth.
    I didnt think that you could use the Bluetooth module with that head unit
    Just asking if you can because I have got the Audi Bluetooth module cheap a while ago but never installed it because I thought it required the rnse to work
    So just wanting to confirm can you use and connect the Bluetooth module to a concert double din head unit
  6. a6_chris
    a6_chris Well-Known Member
    1,883
    159
  7. Gazthesparky
    217
    Brilliant you learn somthing new everyday lol I will bave to check elsa out and get the loom made up that's another job added to my list
    In the future I will be purchasing an rnse but untill then I can use the bluetooth
    To what extent can you use the Bluetooth I have a multifunction steering wheel and dis does it just connect to your phone and the cut the stereo when you receive a call ?
  8. a6_chris
    1,883
    159
    Yep, press the mode button for your phonebook then scroll using the scroll wheel on the left hand side ..
    You can also press the voice button on the steering wheel for voice dialing but I'm not sure what else you can do as mine speaks to me in German and I can't get it changed due to modified software :(
  9. apoc_reg
    apoc_reg Member
    66
    Mine speaks in english and I still struggle to get it to do anything!
    'Dial home', "sorry?", 'Dial home' "Do you want to delete home", 'no!!!' is about how it normally goes!
  10. jb0o
    2,662
    116
    Haha, my voice recognition isn't too bad actually. I use the following to dial a number:
    Me: "Select name"
    Audrey: "Name please"
    Me: "Beth"
    <Repeats my recording of 'Beth'>
    Me: "Dial"
    Audrey: "Number is being dialled"
    My biggest problem is storing a voicetag...
    Me: "Store"
    Audrey: "Star"
    Me: "Delete. Store"
    Audrey: "Star"
    Me: "Delete. Store"
    Audrey: "Star"
    Me: "Stupid ****"
    Audrey: "Pardon?"
    :banghead:
  11. Gazthesparky
    217
    Just another question regarding the Bluetooth and the speech dialling is the SDS part of it a different module or is it done via the BT module ? I've got a MFSW with the mode buttons and speech button
    Also I have a module that ends in a D but I see there are others that end in a E what's the differnces ? And where can I find out the differences between the modules ? Is there a list somewhere ?
  12. jb0o
    2,662
    116
    Voice commands are from the Bluetooth unit itself and SDS is part of the RNS-E Sat Nav system.
    No difference between D & E - both support basic functionality, which means they aren't compatible with the RNS-E Sat Nav. Bluetooth would still work fine if you retrofitted an RNS-E but you wouldn't be able to dial or view phonebook from RNS-E etc.
  13. Gazthesparky
    217
    Ok
    That's brilliant so there's no difference between them
    So does that mean then when I install an rnse in the future I will have to replace the BT module if so which module will I need so that the BT works with the Rnse ?
  14. jb0o
    2,662
    116
    You don't need to install a different bluetooth module, only if you want to unlock the features in the RNS-E which includes the dial, phonebook, received calls and dialled calls.
    You can choose any Bluetooth revision except from A, D, E and ones without a suffix. I'd also stay away from rev K as this one has known firmware issues.
  15. Gazthesparky
    217
    Cheers jb0o
    Can I just check that ive got this correctly my D module will work with the RNSE and my current concert HU and in the future when i retrofit the RNSE it will work but it won't have all the functions you stated If I want all the functions then I need to upgrade the BT
    Unit to any number APART from A,D,E and K ?
  16. jb0o
    2,662
    116
    Yup thats correct.
    rev K will be fully compatable with the RNS-E however a lot of these were replaced under warranty due to a dodgy firware, so best keep away from one of those unless it's dirt cheap.
    I've got rev 'H' in my A3 and works perfectly with the RNS-E.
  17. NHN
    29,280
    1,692
    Cant see why you cant change this tbh.
  18. a6_chris
    1,883
    159
  19. Gazthesparky
    217
    Hi can I just double check will a BT unit ending in a S work in a A4 B7
    It states it is a Europe module
    Just want to check cheers
  20. NHN
    29,280
    1,692
    Yes
  21. Gazthesparky
    217
    Cheers NHN
  22. paul_e88
    paul_e88 New Member
    25
    Just a quick bluetooth question.
    On a Concert II+/Symphony II+, without MFSW, will the bluetooth module work?
    Can it be controlled only by phone, or is it completely unusable?
    Thanks.
  23. a6_chris
    1,883
    159
    Depends on the phone
  24. paul_e88
    paul_e88 New Member
    25
    What do you mean? what is the phone supposed to have, besides bluetooth?
    I was reffering to making and receiving calls just using the phone, and then talking through the car kit. Any phone can make and receive calls..please be more specific.
    Thanks..
  25. a6_chris
    1,883
    159
    Well on some phones when a Bluetooth connection is established the phone locks out certain functions.
    I asked because on an iPhone the software still allows you to dial from the phone but still keep the Bluetooth connection enabled.
  26. paul_e88
    paul_e88 New Member
    25
    Ok, i get it now. I was going to use an iphone, so i think it's ok.
    I remember i connected a lot of BT accesories, like BT receiver, BT ear piece, on a couple of phones and they all worked just like they usually do, that's why it sounded weird to me. :)
    I have a '04 A3 and a three spoke steering wheel, so no MFSW is available, there is only a 4-spoke ugly MFSW which i'm not going to use. RNS-E remains the only option to control the BT module, but that RNS-E is too expensive for me, so for a while i'll stick to controlling it though the phone.
  27. a6_chris
    1,883
    159
    No problem - my post was rushed but glas you understood it.
    My work phone a Samsung something or other locks out the phone when connected to the car so thats why I was wondering which phone you had but the iPhone works as normal when connected so you should be fine.
    You will need to answer the phone from the handset though but it should divert the audio to the bluetooth automatically.
  28. kolash
    kolash Member
    46
    Not sure if you got round to this but, I have just done this same upgrade and all works very well. The concert does not display phone contact info but it should be visible on the DIS in the instrument cluster.
    I agree the phone works fantastically through the RNS-E, you can access all your dialled/missed/received call lists as well as the phone book.
    You need VCDS to recode the phone module and RNS-E when installing to ensure all functionality works.
