Audi BT - Nokia E51 & Samsung U700 no phone book
mattandrew Feb 5, 2008
  1. mattandrew
    mattandrew Member
    977
    21
    Got a problem with my phone book sync with the above phones.
    Used to have no problems with my Nokia 6300 all downloaded ok.
    All numbers are stored on the phone on the E51. Is anyone else having similar issues
    Thanks Matt
  2. Nelson_R32
    Nelson_R32 Member
    305
    Nokia E and N series are a bloody nightmare bluetooth-wise...and that's not just referring to Audi.
    I hear software/firmware updates on the Nokia websites can bring the phonebook up in some cases. Might be worth giving that a try.
  3. cooni
    cooni Member
    171
    So many people seem to ask about this, but it's quite straight forward...
    1. Delete any pairing between the phone and the car.
    2. Download and install the .sis file from
    http://europe.nokia.com/A4143881 to your phone. (There's a few versions there, the E51 is a 3rd edition phone so just use that one).
    3. Open the "Download" application on the phone (it's installed under "Applications" after installing the above)... It will just say "Processing", and appear to do nothing.
    4. Switch on the car and pair the phone again. After a short while the "Download" program will transfer the contacts to the car.
    This should work for pretty much all Nokias that people have troubles with.
  4. s8craig
    1,753
    56
    This will only work in an A3/A4 with the latest version Q phone module
  5. gr1zly
    gr1zly Member
    207
    You will have phonebook only if you have mobile without Symbian...
  6. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    OR if you download a patch from the Nokia website onto your Symbian-based Nokia phone (doesn't work with all models, but it does with most).
