Tonychestnut
Hi All
this is a similar issue to one other I have seen here however with subtle differences as follows.
A6 2.0l 6 speed.
Issue
Car hesitates/jerks and runs rough anywhere from 1200 rpm to 2200 rpm.
When accelerating from stopped, when the car reaches approx 1800 rpm in 1st, the car suddenly hesitates or jerks. Same thing happens in second and so on up through the gears but less noticeably in higher fears. When cruising, it manifests as a roughness in the engine. It can be so bad that you can see it on the rpm gauge. When it starts to happen in 1st, if you hold the throttle steady at the same rpm, the engine hunts ie, speeds up and suddenly dies etc etc. It is also producing a lot of black smoke on acceleration and is generally down on power.
It has gotten to the stage when it is continually happening when cruising on the motorway at around 2000 rpm which is rendering the car practically undriveable..
The following has been done.
Fuel filter changed and fuel tested for oil (non present)
EGR Valve replaced
Mass Airflow Sensor Replaced
Intake manifold removed and cleaned.
Turbo intake hose checked for leaks (none
ECU Upgraded to newest version of software available (by Audi)
Total spend over €1000
All to no avail.
Two interesting points however,
When I disconnect the Mass Airflow Sensor, the car runs perfectly smoothly all the time (if very slightly down on power). I understand that disconnecting the MAF tells the ECU to leave the EGR Valve closed.
In addition, on first start when the engine is stone cold, the issue never happens when I go up through the gears for the first time but after a minute or so, it starts to happen and then continues.
Any help anyone, I am pulling my hair out and am beginning to think that the only way to fix the problem is to buy a box of matches !!
A6 2.0l 6 speed.
Issue
EGR Valve replaced
All to no avail.
