Audi A6 clucth problem
ricky80 Apr 25, 2005
  1. ricky80
    ricky80 New Member
    14
    Need help, can anyone tell me where the salve cylinder is on a Audi A6 2.4 V6 on a 1996. The reason I want to know is I am losing brake fluid but can't find any leaks. When you push the clutch down for long periods of time in 1st gear i.e traffic lights the car suddenly starts moving forward. When you go to pull away the bitting point is very low. I have to put my foot under the clutch pedal to bring it back up. Has anyone else had this problem or does anyone have any ideas what could be causing this.
    Thanks for your time.
  2. audi5e
    audi5e Member
    809
    you should find the slave cylinder on the top of the gearbox right near the bell housing (positioned here so it can disengage/push the clutch lever).
    could be air in the hydraulic system caused by your leak. it may also be a case of a worn clutch?
  3. Rev-head
    Rev-head Active Member
    2,987
    I agree with Audi5e more than likely seals have gone in the slave cylinder by the sounds of it as you lose pressure through the leak causing the clutch to engage onto the fly wheel
  4. ricky80
    ricky80 New Member
    14
    thank for all your help is his a gear box out job or not im looking in to it and will let you know thanks again
  5. ricky80
    ricky80 New Member
    14
    job done thanks for your help it was the slave cylinder all running well now thanks again
