Hi , all
First of all I'm sorry for my bad grammar , English is not my strong size , but I try to explain what kind of problem I had
I need to reprogramm my car's ABS/ESP module and set steering wheel angle. I try , but something is wrong.
My car is :
Audi A6(c5) Avant
2002 year
1.9 TDI ( engine code AWX 96kw/130hp.)
Manual gearbox
ABS modul is Bosch ESP 5.7
4B0 614 517 G
And brake type is 1 LB
That's how I try :
1) Switch ignition On
2) Connect the VCDS to my car
3) Go to ABS Brakes
4) Then I go to this link http://wiki.ross-tech.com/wiki/index.php/Audi_A6/S6/RS6/allroad_(4B)
5) There I select my type car , than [03] - brake electronics & than Bosch 5.7
6) There is nummbers I need , if I understand it correctly I need Login 07555 & Coding 06255. Correct ?
7) Than back in VCDS I select Login and enter 07555
8) Than I select Coding and enter 06255
And right now my problems begin
VCDS reconnect's to ABS , than it shows that soft coding is 00000 & wsc 00000
And nothing happens.
Can anybody explain what I doing wrong , why I can't reprogram ABS ?
Hopefully you can understand what kind of problem I had
My car is :
Audi A6(c5) Avant
2002 year
Manual gearbox
4B0 614 517 G
That's how I try :
3) Go to ABS Brakes
