Audi A6 4G
amar06fbr
Vorsprung Durch Technik
West Yorkshire
hi chaps, iv retrofitted the new led xenons into a A6 4G iv used the kufatec wireing. the instruction on the coding part is somting i dont understand and i cant code them :( the drl are working but the cornering lights are on with the drl and theres no flash. anyone got the coding?
thanks
A.
this is the coding i got of kufatec ins;
encoding
To carry out the vehicle code, please contact an Audi party. connection
establish the diagnostic unit - choose vehicle self-diagnosis. Please complete the coding
Step by step in accordance with the following illustrations by.
address 09
Byte 00 - HEX - 26
Byte 02 - HEX - 20
Byte 06 - HEX - 9F
Byte 14 - HEX - 1D
Byte 15 - HEX - 0C
Can you post a diagnostic scan of your car to show the current coding for module 09
Hopefully we can then advise what needs to be changed.
Steve
Hi Steve, thanks for the reply, yea here is the scan;
Chassis Type: 4G0
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 5F 62 72
VIN: WAUZZZ4G6CN082751
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CGLC) Labels: 03L-906-018-CGL.clb
Part No SW: 03L 906 018 LA HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 2023
Revision: 45H25---
Coding: 12194012242401080000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM20TDI01103L906018LA 003009
VCID: 74ECABBEDF0A33B835D
1 Fault Found:
10065 - Mass Air Flow Sensor (G70)
P0104 00 [167] - Intermittent
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 19588 km
Date: 2012.05.07
Time: 00:24:28
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 4G0-907-379.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 06A087016005E1808B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004028
VCID: 366851B689F661A8CB9
2 Faults Found:
0687 - Function Restriction due to Received Malfunction Value
U1113 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 17
Mileage: 19588 km
Date: 2012.05.07
Time: 00:23:21
0688 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 19588 km
Date: 2012.05.07
Time: 00:23:18
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BG HW: 4H0 907 064 BG
Component: BCM2 2.0 H31 0333
Revision: 00002001
Coding: 03B93006000000000000
VCID: 6FE6A4D2BE2C1060C8F
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H39 0046
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 3
Reset counter: 16
Mileage: 19588 km
Time Indication: 0
Date: 2012.05.07
Time: 00:23:25
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4G0 820 043 G HW: 4G0 820 043 G
Component: KLIMA 2 ZONEN H10 0062
Serial number: 09111100040966
Coding: 34220008A0
ASAM Dataset: EV_AirCondiBasisUDS 002037
ROD: EV_AirCondiBasisUDS.rod
VCID: 234E98E22A64E4001C7
3 Faults Found:
0267 - Sensor for Refrigerant Pressure and Temperature
B10C2 21 [009] - Signal Amplitude Too Low
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 232
Mileage: 19588 km
Date: 2012.05.07
Time: 01:17:47
0276 - Engine Off Timer Performance
P150A 00 [009] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 232
Mileage: 19588 km
Date: 2012.05.07
Time: 00:00:48
0315 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 231
Mileage: 19588 km
Date: 2012.05.07
Time: 01:17:47
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 BA HW: 4H0 907 063 A
Component: BCM1 2.0 H12 0100
Revision: 12012002 Serial number: 00000001103011
Coding: 690000108034A7600405008000005F5F0F9D860827080101000004402000
VCID: 68D4CFCE9BC2C758895
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A
Component: WWS57X 110926 H35 0051
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 HW: 4G0 941 531
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
4 Faults Found:
02394 - Parking Light Left Front (M1)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 17
Mileage: 19588 km
Time Indication: 0
Date: 2012.05.07
Time: 00:43:00
02395 - Parking Light Right Front (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 17
Mileage: 19588 km
Time Indication: 0
Date: 2012.05.07
Time: 00:43:00
02745 - Bulb for Daytime Running Light; Left
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 19588 km
Time Indication: 0
Date: 2012.05.07
Time: 00:43:00
02746 - Bulb for Daytime Running Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 19588 km
Time Indication: 0
Date: 2012.05.07
Time: 00:43:00
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901131202858
Coding: 080207
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000.rod
VCID: 3B7E4082B2D4BCC0347
No fault code found.
Address 15: Airbags (J234) Labels: None
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG005BHH2
Coding: 30323436313230303235554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405R0UJCIBH14
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB405L0TGJED90Y
Crash sensor for side airbag; rear driver side:
Serial number: 3515JRB405J0TO4MCHNF
Crash sensor for side airbag; rear passenger side:
Serial number: 3525JRB405F0TGJI615I
Crash sensor for front airbag; driver side:
Serial number: 3554VRB405L0TO4ONHF.
Crash sensor for front airbag; passenger side:
Serial number: 3564VRB405L0TO4OHPM4
1 Fault Found:
1048581 - Databus
U1123 00 [008] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 17
Mileage: 19588 km
Date: 2012.05.07
Time: 00:23:20
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20111108000412
Coding: 000015
VCID: 306467AE63924F98915
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 950 K HW: 4G8 920 950 K
Component: MDieGb H34 0209
Revision: 25450205 Serial number: 658081111593046
Coding: 33A4100003012600010000
ASAM Dataset: EV_RBC7KMID 004045
ROD: EV_RBC7KMID.rod
VCID: 37765CB28EFC98A0D0F
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 F HW: 4G0 907 468
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000275450
Coding: 00CD074400
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 336E68A29A847480EC7
Control unit for battery monitoring:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790924589
Voltage stabilizer:
1 Fault Found:
4875 - No Communication with Instrument Cluster
U0155 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 19588 km
Date: 2012.05.07
Time: 01:55:04
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 HW: 4G0 907 637
Component: SARA 3D H02 0004
Revision: -------- Serial number: EJ1BPA3200VK3A0
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_AU57.rod
VCID: EBDE30C202346C40647
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011C16204001620002080002
Shop #: WSC 02312 785 00200
VCID: 42803D66DD3ECD08771
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4G0 909 144 J HW: 4G0 909 144 G
Component: RCEPS H35 0008
Revision: 00001000 Serial number: 0029248771
Coding: 101000010000
ASAM Dataset: EV_RCEPS 007007
ROD: EV_RCEPS.rod
VCID: 306467AE6B924F98915
1 Fault Found:
5258753 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 232
Mileage: 19588 km
Date: 2012.05.07
Time: 00:42:42
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0162181465
Coding: 013B062220B9044083200904000104000000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
3 Faults Found:
00218 - Humidity Sensor (G355)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 231
Mileage: 19588 km
Time Indication: 0
Date: 2012.05.07
Time: 01:04:10
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 16
Mileage: 19588 km
Time Indication: 0
Date: 2012.05.07
Time: 00:23:25
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 16
Mileage: 19588 km
Time Indication: 0
Date: 2012.05.07
Time: 01:55:05
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: 4182326AD838D6106EB
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000172740
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake.rod
VCID: 2A5075C64D4E35485F1
1 Fault Found:
465152 - Function Restriction due to Received Malfunction Value
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 17
Mileage: 19588 km
Date: 2012.05.07
Time: 00:23:20
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 4G0 035 193 D HW: 4G0 035 193 D
Component: RMC Cnct Nav H52 0761
Coding: 0101010001415B47002B060301010000010000
VCID: 244C9BFE276AE33865D
Subsystem 1 - Part No: 8X0 919 884 D
Component: P13-50-11.06 0002
Subsystem 2 - Part No SW: 4G0 919 603 HW: 4G0 919 603
Component: DU6 Basic H42 0084
Subsystem 3 - Part No SW: 4G2 919 710 B HW: 4G2 919 710 B
Component: E380 BDT C7 H11 0204
1 Fault Found:
02259 - Information Display and Control Head (Front) (J685)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 16
Mileage: 19588 km
Time Indication: 0
Date: 2012.05.07
Time: 01:04:05
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010814204001620002080002
VCID: 448C3B7EC72AC33845D
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H04 0212
End ---------------------------------------------------------------------
this scan was after i cleared all faults, the is kind of striped atm lol.
Have you got the self levellers for the suspension and a new front bumper with washer jets? If not, you're not legal :)
If I recall correctly (open to criticism on this btw) you should have two stray wires coming from the wiring adapter which need to be plugged into your central conv module under the steering wheel.
erum working on them, but will be looking to fit them later on because my a3 is curently not on the road and i need a car :( so am going to do them after i get my a3 back on the road.
yeap i have wired the 2 wires into the central conv.
encoding
address 09
Byte 00 - HEX - 26
Byte 02 - HEX - 20
Byte 06 - HEX - 9F
Byte 14 - HEX - 1D
Byte 15 - HEX - 0C
Are you saying you tested this coding & it didnt work or you just dont know how to implement the coding given above?
Are you saying you tested this coding & it didnt work or you just dont know how to implement the coding given above?[/QUOTE
nope i havent tried that coding because vcd dont have HEX listed and on each bit under the byte there boxes to be ticked an untick but dont have info on what each bit is for.
Did you manage to code the LED headlights for your A6? I am currently installing the bi Xenons on my A6.
