Audi A5 retrofitted cruise control.. need help with high beam not staying on
andys clifford May 11, 2013
  1. andys clifford
    andys clifford New Member
    9
    I retro-fitted a whole new stalk column and found that when i push for high beam it doesn't click ... it isn't broken i have a vw caddy and when you push the stalk forward it springs back but the full beam is still on until you pull back on the stalk... my audi doesn't do this and just acts like im flashing someone... is there anywhere in coding i can change the characteristics of the high beam..
    i have a genuine vcds cable
  2. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    You have the wrong stalk fitted.
    Same applies to the A3.
    Post your car year and the part number of the switch pack you fitted.
  3. pns2007
    pns2007 Moonstone Grey VCDS Map User
    675
    55
    Same happened to me when I did my A3. Audi gave me the wrong stalk. Its not a coding issue you will need a new stalk!
  4. NHN
    29,345
    1,719
    It can be coded on some chassis, A5 more than likely & A3 from certain years, post a log of your actual car then we can help further.
  5. andys clifford
    9
    I'm sorry that i havent replied, right!... i have the scan of my car, hopefuly it can be recoded to suit the new stalks...
    Monday,03,June,2013,23:14:50:33274
    VCDS Version: Release 11.11.6 (x64)
    Data version: 20121223
    Chassis Type: 8T0
    Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56
    VIN: WAUZZZ8T18A028182 Mileage: 85440km/53089miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine (J623-CALA) Labels: 06E-907-559-CAL.clb
    Part No SW: 8T0 907 559 D HW: 8T0 907 559 A
    Component: 3.2 SIMOS8.2 H02 0003
    Revision: --------
    Coding: 0114000302070121
    Shop #: WSC 06325 123 12345
    ASAM Dataset: EV_ECM32FSI8T0907559D A01002
    ROD: EV_ECM32FSI8T0907559D.rod
    VCID: 43830A7ECA1422007D9
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
    Part No SW: 8K0 927 155 HW: 0AW 927 156 H
    Component: 0AW 32 AVSRdW H04 0011
    Revision: --H04--- Serial number: 0000001029
    Coding: 000001
    Shop #: WSC 06795 666 30556
    ASAM Dataset: EV_TCMVL381 A02006
    ROD: EV_TCMVL381_AU48.rod
    VCID: F0E915B22B22699850B
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 R HW: 8K0 907 379 R
    Component: ESP8 front H04 0210
    Revision: -------- Serial number: --------------
    Coding: 0E4500
    Shop #: WSC 06325 000 00000
    VCID: 48991D52FB320158A8B
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 289 C HW: 8K0 907 289 C
    Component: BCM2.01 H38 0253
    Revision: 00003002
    Coding: 011000
    VCID: 397F6896B0D868D0275
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H35 0052
    Subsystem 2 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
    Component: ELVAUDIB8 H35 0039
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T2 820 043 M HW: 8T2 820 043 M
    Component: KLIMA 3 ZONEN H05 0120
    Revision: D0000000 Serial number: 0107.01.080078
    Coding: 46060000
    VCID: 3C717182BFEA5DF83C3
    1 Fault Found:
    01206 - Signal for Duration of Ignition Off Time
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 9
    Mileage: 84589 km
    Time Indication: 0
    Date: 2013.05.10
    Time: 18:58:43
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
    Component: BCM1 1.0 H21 0253
    Revision: 04021001 Serial number: 00000000072368
    Coding: 2600DA914114AF310009000000005D5D001D438800010141000000
    VCID: 2F6B56CE7E9CB660891
    Subsystem 1 - Part No SW: 8T2 955 119 C HW: 8J2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 161207 H11 0040
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0002
    Coding: 02532C
    Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
    Component: E1 - LDS H07 0070
    3 Faults Found:
    01500 - Bulb for Fog-Lamps; Right (L23)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 83245 km
    Time Indication: 0
    Date: 2013.04.17
    Time: 17:57:00
    03110 - Active Steering Control Module (J792)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 83245 km
    Time Indication: 0
    Date: 2013.04.17
    Time: 17:57:00
    03207 - Charisma Switch Module
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 83245 km
    Time Indication: 0
    Date: 2013.04.17
    Time: 17:57:00
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 B HW: 8K0 919 475
    Component: PARKHILFE 4K H06 0010
    Revision: 11001001 Serial number: 75330800901892
    Coding: 000101
    VCID: 38796D928BD271D8D8B
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H12 0013
    Revision: -------- Serial number: 90304HFT0006T
    Coding: 000036
    Shop #: WSC 00836 210 50786
    VCID: 3D777C86A4F054F00BD
    Component: E221 - MFL H02 0003
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8T0 920 981 A HW: 8T0 920 981 A
    Component: KOMBIINSTR. H25 0214
    Revision: 00000000 Serial number: 71V31UK97
    Coding: 232F000002002600010001
    VCID: 3A7D779AB5DE63C82EF
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 D HW: 8T0 907 468 D
    Component: GW-BEM 5CAN H04 0084
    Revision: GA801030 Serial number: 3000G07B26800C
    Coding: 000003
    Shop #: WSC 00847 210 86469
    VCID: 428D0F7ADD0E2B0876F
    Subsystem 1 - Part No SW: 8K0 915 181 HW: 8K0 915 181
    Component: J367-BDM H06 0150
    1 Fault Found:
    03041 - Energy Management Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 8
    Reset counter: 22
    Mileage: 83509 km
    Time Indication: 0
    Date: 2013.04.22
    Time: 16:51:00
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00003002 Serial number: 0107929179
    Coding: 011F168200390400033000
    Subsystem 1 - Part No: 8K0 951 177
    Component: DWA-Sensor H02 0030
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    5 Faults Found:
    02738 - Bulb for Tail/Brake Light; Left
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 253
    Mileage: 82727 km
    Time Indication: 0
    Date: 2013.04.06
    Time: 19:31:55
    02740 - Bulb for Tail Light 2; Left
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 253
    Mileage: 82727 km
    Time Indication: 0
    Date: 2013.04.06
    Time: 19:31:55
    02616 - Fuel Tank Cap; Unlock
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 245
    Mileage: 82731 km
    Time Indication: 0
    Date: 2013.04.06
    Time: 20:01:26
    02615 - Fuel Tank Cap; Lock
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 2
    Fault Frequency: 14
    Reset counter: 28
    Mileage: 82733 km
    Time Indication: 0
    Date: 2013.04.06
    Time: 20:25:20
    01501 - Bulb for Blinkers; Rear Left (M6)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 25
    Mileage: 84195 km
    Time Indication: 0
    Date: 2013.05.04
    Time: 16:21:41
    Address 55: Xenon Range Labels: 8K0-907-357.clb
    Part No: 8K0 907 357 A
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000001
    Shop #: WSC 06324 000 00000
    VCID: 33635ABE52B49280ED9
  6. andys clifford
    9
    Chassis Type: 8T0
    Revision: --------
    Coding: 000001
    Coding: 0E4500
    Revision: 00003002
    Coding: 011000
    Coding: 46060000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 9
    Mileage: 84589 km
    Time Indication: 0
    Date: 2013.05.10
    Time: 18:58:43
    Coding: 00FD11
    Coding: 02532C
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 83245 km
    Time Indication: 0
    Date: 2013.04.17
    Time: 17:57:00
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 83245 km
    Time Indication: 0
    Date: 2013.04.17
    Time: 17:57:00
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 83245 km
    Time Indication: 0
    Date: 2013.04.17
    Time: 17:57:00
    Coding: 000101
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
    Component: AirbagVW-AU10 H26 0410
    Serial number: 0038JD12JKRQ
    Coding: 30323433363030303030554A305238543053
    ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 3C717182B7EA5DF83C3
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME29722F52H
    Crash sensor for side airbag; passenger side:
    Serial number: 6344MSME37106B6AI
    Crash sensor for side airbag; rear driver side:
    Serial number: 6352QSME522D3C47P
    Crash sensor for side airbag; rear passenger side:
    Serial number: 6362QSME522C0A07G
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME4D791221
    Crash sensor for front airbag; passenger side:
    Serial number: 63832SME4D7A247BF
    Coding: 000036
    Coding: 000003
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 8
    Reset counter: 22
    Mileage: 83509 km
    Time Indication: 0
    Date: 2013.04.22
    Time: 16:51:00
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 A HW: 8K0 959 793 A
    Component: TSG FA H09 0149
    Revision: Serial number: R…w
    Coding: 0110022244012201
    VCID: 3E757B8AA9F64FE8127
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 253
    Mileage: 82727 km
    Time Indication: 0
    Date: 2013.04.06
    Time: 19:31:55
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 253
    Mileage: 82727 km
    Time Indication: 0
    Date: 2013.04.06
    Time: 19:31:55
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 245
    Mileage: 82731 km
    Time Indication: 0
    Date: 2013.04.06
    Time: 20:01:26
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 14
    Reset counter: 28
    Mileage: 82733 km
    Time Indication: 0
    Date: 2013.04.06
    Time: 20:25:20
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 25
    Mileage: 84195 km
    Time Indication: 0
    Date: 2013.05.04
    Time: 16:21:41
    Address 47: Sound System (J525) Labels: 8T0-035-223-BOC.clb
    Part No SW: 8T0 035 223 L HW: 8T0 035 223 B
    Component: DSP Prem H11 0170
    Revision: 00H11001 Serial number: 34832000509302
    Coding: 0203010301
    VCID: 377B6EAE86CC7EA0D11
    1 Fault Found:
    02095 - Component Protection Active
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 253
    Mileage: 84195 km
    Time Indication: 0
    Date: 2013.05.04
    Time: 17:23:06
    Freeze Frame:
    Voltage: 12.50 V
    Temperature: 26.0°C
    Temperature: 24.0°C
    Bin. Bits: 00000100
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 A HW: 8K0 959 792 A
    Component: TSG BF H09 0149
    Revision: Serial number: •w
    Coding: 011002224C012201
    1 Fault Found:
    02115 - Locking Unit for Central Locking
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 19
    Mileage: 85089 km
    Time Indication: 0
    Date: 2013.05.25
    Time: 21:15:12
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
    Component: EPB Audi B8 H03 0040
    Revision: 00000003 Serial number: 00000000050902
    Shop #: WSC 00000 000 00000
    1 Fault Found:
    00381 - Databus Instrument Cluster
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 253
    Mileage: 84195 km
    Time Indication: 0
    Date: 2013.05.04
    Time: 15:41:42
    Freeze Frame:
    Voltage: 12.50 V
    Count: 81
    Speed: 0.0 km/h
    Hex Value: 0x4063
    Hex Value: 0x0008
    Hex Value: 0x1010
    Coding: 0000001
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8T2 035 186 A HW: 8T2 035 186 A
    Component: Concert3 DAB H10 0310
    Revision: 00000507 Serial number: AUZ5Z6G1004263
    Coding: 0003008001040D02437B070000
    VCID: 366563AA81C687A8CA7
    Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
    Component: Display
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 254
    Reset counter: 248
    Mileage: 82727 km
    Time Indication: 0
    Date: 2013.04.06
    Time: 19:32:34
    Freeze Frame:
    Bin. Bits: 10000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    End ---------------------------------------------------------------------
