Audi A5 rear cluster LED change
Rajdaman69 Jun 20, 2013
  1. Rajdaman69
    Rajdaman69 New Member
    24
    Hi,
    Is there anyone out there that knows much about changing pre 2009 standard rear clusters to newer led clusters?
    I have fitted the led clusters in however the wiring plugs are different on both units ( led has more wires ) I was lead to believe that they were plug and play - with a bit of coding but I was wrong :( is there such thing as adapters, or wiring looms that convert these?
    has anyone done anything out there that has made it work? Or can anyone out there do it?
    kind Regards
  2. NHN
    29,353
    1,720
    Are yours the original A5 rear clusters or original led versions?
    You may need a new module & harness or someone to convert it, vcds or a dealer to adapt.
    I maybe able to do this for you.
  3. Rajdaman69
    24
    Hi,
    They are genuine Audi Led clusters. I can provide the part numbers if you wish?
    Kind Regards
  4. NHN
    29,353
    1,720
    I meant which version of clusters, as there were halogen, then led & now the newer led type iirc, yeah what's the part numbers?
  5. Rajdaman69
    24
    I'll get you the part number tomorrow, how ever for now I can confirm they are the LED clusters from late 2009-2012.
    Kind Regards
  6. Rajdaman69
    24
    Hi,
    The part number for one of them is 8T0 945 093A ( 19/11/10 ) version
    kind Regards
  7. lee_w
    lee_w New Member
    12
    Hello,
    I want to do the same thing as you. Audi are charging £700 for the kit which includes the lights, module & harness. They will fit for £180. I don't think there is a cheaper way. I have rung a few places about coding the lights but think its a big job by the sounds of things and people not wanting to do it. If you have any luck then let me know. Mine is an 08 audi A5 3.0tdi
    thanks Lee
  8. gcon45
    gcon45 Member
  9. lee_w
    lee_w New Member
    12
    I have sent them an email now. Great find, thanks :)
  10. lee_w
    lee_w New Member
    12
    The company replied saying that the lights might still need coding so it would be cheaper buying them from audi for £700
  11. Rajdaman69
    24
    However Audi have said they will supply the retro kit, but not fit it in, as they wish not to take any chances of blowing anything else whilst s installing it.
    Helpful Audi as standard! NOT!!!
    Regards
  12. lee_w
    lee_w New Member
    12
    Rajdaman69 - yeah thats right, i only found one Audi dealer that would supply and fit, the rest said they would supply but not fit. Not very helpful at all. Starting to think its more hastle than its worth trying to get these lights fitted. I should have just waited and gone for a 2010 model with the lights already installed
  13. RS5UK
    RS5UK Member
    Sorry, I know this is an old post but I've just joined the site and wondered if you have sorted this? PM me if not and I can point you in the right direction or may be able to help with the coding.
  14. momzz
    momzz New Member
    Hi mate I'm changing my tail lights to led, was going to ask how much do u charge? thanks
  15. anthonyr
    anthonyr New Member
    same here mate, i am interested too :)
