Audi a4 wiper replacement
Slide the end of the wiper arm/blade off if i remember right theres a tab on the top you have to push down and then the wiper blade will fall out. Replace the new blade and slide the plastic cap back.
It's a b***h to replace these wiper blades!
Did mine yesterday, there's a clip that slides up, it's very tight so be patient - i broke the clips on the original wipers but my replacement Audi OEM one's came with clips.
Should be a straight swap from there on.
When sliding the clips back into place I found it easier to have the wiper flat against the windscreen and then slide the clip till it clicks into place.
Reactions: vitorcosta
Alternatively, check out Ravi's guide on how to do it during reruns of Top Gear on Dave.
Ravin it!!
as said before its just a tab that lifts up or slides out (cant remember which) I just used the end of my key 5 mins later it was all done.
