Audi A4 'Water Pistol' to VW Passat 'Fan Jet' Conversion....
Richardesty Jan 19, 2009
  1. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado quattro Audi S4 Black Edition s tronic
    8,042
    2,494
    My pair of jets has just arrived from Poland. Four days, including a weekend is pretty impressive.
    Can't get out there to fit them just now, as it's raining.
    Looking at them, there is a small hole just to the side of the fan jet, which I am presuming is the adjuster. I hven't examined it too closely yet, but am guessing it takes a small allen key. Can anyone confirm this is the adjuster, and if so, which way it works; i.e. clockwise for up etc?
    EDTE: Soon figured out the adjuster; in fact, it took a tiny torx bit. The jets are fitted and working. As per the guide, I packed them using cardboard and once I'd got them positioned, applied liberal quantities of PVA adhesive. I've left the cardboard in place while the adhesive goes off. Whole process took half an hour, and I am a useless clutz. Someone who knows what they're doing and has a normal supply of hand/eye co-ordination will manage it in half the time.
    Jespy likes this.
  2. rizzini7
    rizzini7 Active Member VCDS Map User
    951
    146
    43
    Right, well apparently it's gonna take me even longer!!! So much so I gave up :). When you say packed with cardboard what did you do mate??? Thanks in advance
  3. jdp1962
    8,042
    2,494
    The plastic oval surround is about 2mm narrower than the standard ones, so when you position it in the hole in the underside of the bonnet, there's a 2mm or so gap between the surround and the leading edge of the hole - i.e. the edge towards the front of the bonnet - for most of its length. This means none of the little retaining lugs engage, so it doesn't stay in place unassisted. So you need to use an adhesive between the surround and the bonnet where the two surfaces touch. You also have to stuff something into the afore-mentioned gap to hold everything in place until the glue has bonded. i used some folded cardboard. Once the glue had gone off, I eased the cardboard out, and then ran a bead of silicon sealant along the gap to close it up.
  4. rizzini7
    951
    146
    43
    Good work, will give it a go tomorrow probably. Me and DIY don't go. Although I managed to change air filter, map sensor and clean throttle body today. And downside managed to break shaft on rear wiper doing Q5 wiper conversion :( so need a new motor now
    Thanks mate
  5. rizzini7
    951
    146
    43
    Lol, finally got round to fitting them. Adjustment doesn't seem to do much though?? Assume its clockwise for up? Just thought it would adjust to the middle of the screen. Hitting around the wiper position currently
    Edit
    Just reread and saw they need to be screwed right in to max adjustment for best results. Will try later. They appear to be glued reasonably flush
  6. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    *Adds to long list of mods to do.* :readit:
  7. jdp1962
    8,042
    2,494
    It's quick and cheap, so put it at the top of the list.
  8. olethalb
    olethalb Active Member
    357
    76
    *bookmarked
  9. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Done this mod the other day while my car is on stands in the garage getting brakes done. However I held them up in place using tape and used epoxy putty to fill the gap and hold them in place. Once it had set I went over with a black paint pen (as the putty is grey in colour) to tidy it up a bit more. Much neater finish than glue IMO.
  10. MattUK
    MattUK Member
    97
    17
    A quick query.. where have you guys been ordering parts from which need shipping from Poland ?
    Matt
  11. ruairi83
    ruairi83 Well-Known Member Team Sepang quattro Audi A4 Black Edition
    1,534
    469
    I've a new set of these available if anyone interested as sold car. Effort fitting...
  12. Shaf
    Shaf New Member
    I'm interested mate. How much would you accept?
  13. ruairi83
    1,534
    469
    £26 posted mate. Pm'd you.
    martin1984 likes this.
  14. Visa_broke
    Visa_broke Member
    167
    anyone have a list of what cars came with these fitted?
