Audi A4 'Water Pistol' to VW Passat 'Fan Jet' Conversion....
Richardesty Jan 19, 2009
  1. Richardesty
    Richardesty loves quattro
    742
    20
    How to convert your Washer Jets.......from Audi A4 B7 'Water Pistol' to VW Passat 'Fan Jet (part no 5MO 955 986 9B9 - heated version)
    Some Before and Afters:
    A step by step guide:
    And some moving images:
    :think:
    ruairi83, VagPro and AliGod78 like this.
  2. JohnS3
    JohnS3 Active Member
    3,032
    It's on my to do list....
  3. NHN
    29,344
    1,719
    Yeah had mine for the A3 for few months but was lower down on my list to fit, does require as above some glueing or sealant as the fitment for the audi's is deeper than the passat, but connections are same for A3, passenger side needs either the loom pulling slightly over to plug in or cutting & extending by couple of inches.
  4. JohnS3
    3,032
    Morning Nige. Busy weekend by chance ???
  5. auroan
    auroan Active Member
    1,669
    How much was the passet unit ?
  6. JohnS3
    3,032
    About £13 each from a dealer
  7. Richardesty
    742
    20
    Didn't need to do this with the A4 - it was just a case of 'plug (glue) & play' :o.k:
  8. auroan
    1,669
    Now I need to figure out if I like the jet or spray pattern.
  9. NHN
    29,344
    1,719
    John beat me to it, yeah £13
  10. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    nice info you have put up i like it wonder if they will fit b5's?
  11. NHN
    29,344
    1,719
    Depends on how much time u have to make it fit, lol
  12. NHN
    29,344
    1,719
    Sorry fella didnt see this one, well if honest did literally nothing mainly cause bloody weather & stupid cough wont go away & when it starts it takes ages to die down, but got some stronger drugs now so hope resolves
    I only got new battery installed(varta silver dynamic), oil change & the onboard K module installed this weekend which considering the list I had for this weekend is very ****, had so many wiring jobs to do, was disappointed overall, but tomorrows another day for sure & also discovered a boiled egg in my tyre so considering wheel/tyre upgrade now given tyres usually done in pairs anyway, not happy about that tbh as more money & got more important things to do on car than new wheels etc, but mot, tax & insurance up at end of Jan so has to be done & the main beam wiring, internal **** like lightswitch fixed in place as will fail otherwise, its hanging of cable tie given the trims of for wiring, lol
    But had an idea for mod today for kerb lighting when reversing into a dark space so dont kerb the bloody wheels so much, but it can wait
  13. wfbnadador
    wfbnadador New Member
    this part no. 5MO 955 986 9B9 doesn't seem to turn up any results at all with vw dealers in the US.
    is there a year I can grab for this part? something to get me closer to that jet?
    thanks all!
  14. aragorn
    18,373
    829
    its actually 5M0 not 5MO which might well explain the problem, however i cant find a mention of 5M0955986 in vagcat at all, a google points to it being a valid part number, so perhaps its just too new to be listed on vagcat.
    the 9b9 bit on the end is just the color of the part, so thats not entirely required when searching for it....
  15. aragorn
    18,373
    829
    i think 1T0955986 9B9 is the same part, which is fitted to golfs, might want to try that out.
  16. wfbnadador
    Just wondering what kind of glue people used to hold the sprayer in place... thanks!
  17. Richardesty
    742
    20
    I tried a couple of so called 'extreme glues' before I settled for 'super' glue - because of it's quick grab capacity.
    That said - once I'd positioned them I used a 'prop' to hold them in place for a little while too....
    Rich
  18. A4NA18
    A4NA18 Member
    138
    you can alternatively use blu-tack but it has a higher rate of failure...
    Sorry for my useless input...
    Super Glue should be fine, methinks
  19. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    My wifes Skoda has the fan jet but my RS4 has the water pistol - think I'm going to have to do this mod...
  20. M7R
    M7R Type Approval Engineer,
    216
    looking on etka the r8 uses heated spray jets...anyone know if these are fan ones?
    (my fan ones are still held in by cardboard lol, how many folk have done this mod now?)
  21. JohnS3
    3,032
    The Passat jets are heated, are you not using the heated versions? The R8 jets are handed which may lead to alignment issues. My fan ones are still on the shelf in the garage, one day......
  22. JohnS3
    3,032
    Mmm, digging around in ETKA looks like the A3 and A4 jets are handed too. However the Passat jets are not.
  23. M7R
    216
    I have the passat ones in mine, the original set :ninja:..
    im just wondering if any other cars have a better fit...
  24. Richardesty
    742
    20
    I've got the heated versions......
    As for alignment, you have to have them set to the highest vertical setting for them to be effective, and indeed may need to adjust their horizontal position by refixing their fixed position under the hood. Took me a couple of tries to get them spot on
  25. M7R
    216
    im going to see if i can get a look under the bonnet of a r8 soon, to see if these will work.
    I cant order any though as there are non in the country :(
  26. jwhat
    jwhat Member VCDS Map User
    541
    I have a old crappy one's and this morning at -3C they were not squirting out any water, if I get the passat ones that are heated how do I connect up the heating part? Or are the a4's already heated?
  27. Bing_IRL
    Bing_IRL Member VCDS Map User
    34
    They should be heated already mate. No other reason for them to be plugged in electrically if the existing ones arent heated. That's my understanding anyway.
  28. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,335
    2,877
  29. pburv
    pburv Well-Known Member Team Glacier Gold Supporter Audi S3 quattro saloon DSG
    5,188
    10,855
    Make sure you get the right part number!!:jester:
  30. jdp1962
    8,335
    2,877
    Thanks. I'll be calling Beadles of Dartford this morning. It's the heated ones I'm after.
  31. Darren198712
    Darren198712 Member
    194
    14
  32. jdp1962
    8,335
    2,877
    Hmmmm...I think you'll find that's 10 each, not per pair.
    Still, it beats the price I was quoted yesterday by a VW dealer, which was £20 and some pence each - and the reason I decided not to bother, but to put my energies instead into properly aligning the jets on the current washers.
  33. rizzini7
    rizzini7 Active Member VCDS Map User
    977
    153
    43
    Says priced each near bottom! Still good price, I paid about £17 each from TPS the other day. Also posted from Poland! Although i did order a oem new oil temp sensor from Poland last week and it arrived within 3 days and was only £12.98 posted apposed to £33 over here :)
  34. jdp1962
    8,335
    2,877
    Have you fitted the fan jets yet? If so, would you say it's definitely worth doing? What I mean is; is it simply a nice effect to look at, or does it actually do a better job of cleaning the windscreen?
  35. rizzini7
    977
    153
    43
    Not got round to doing them yet. Still cold and wet outside :). Anything must be better than my current ones though.
  36. jdp1962
    8,335
    2,877
    Well, I've just ordered a pair. Shipping for two is £4.00, so the total cost is £24.00, barely more than the dealer price for one.
  37. rizzini7
    977
    153
    43
    Cant complain at that price, also ordered a Q5 rear wiper aswel to swap over
  38. Darren198712
    Darren198712 Member
    194
    14
    lol I was shattered when I brought them and assumed they were a pair. I will buy another one now lol
  39. rizzini7
    977
    153
    43
    Dont worry, im waiting on my second one as TPS only ordered 1 :wtf:when i asked for two.
  40. jdp1962
    8,335
    2,877
    Don't you mean "bought"?
