audi a4 too many faults
ludbe Nov 26, 2011
  1. ludbe
    ludbe New Member
    Hy,
    first of all sorry for my bad English, because i come from Slovenia:)
    Today i scan my car for faults using VCDS 10.63, but it found 19 faults. I think this is too many faults, and reason must be somewhere else. The car is audi a4 8e, 1.9tdi
    what do you think? What could be the problem?
    This is a saved scan:
    Saturday,26,November,2011,16:30:36:36838
    VCDS Version: Release 10.6.3
    Data version: 20101206
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E04A267170 Mileage: 133390km/82884miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 LJ
    Component: 1,9l R4 EDC G000SG 5934
    Coding: 00002
    Shop #: WSC 63251
    VCID: 6AD0DE2C3CF9
    WAUZZZ8E04A267170 AUZ6Z0D0092846
    3 Faults Found:
    18097 - Powertrain Data Bus: Implausible Message from Elect. Load Controller
    P1689 - 35-10 - - - Intermittent
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 35-10 - - - Intermittent
    18043 - Powertrain Data Bus: Missing Message from A/C Controller
    P1635 - 35-10 - - - Intermittent
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 4529
    Coding: 04255
    Shop #: WSC 07155
    VCID: E5CA2D1055E7
    2 Faults Found:
    00526 - Brake Light Switch-F
    36-10 - Open Circuit - Intermittent
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AA
    Component: A4 Klimaautomat 1324
    Coding: 00000
    Shop #: WSC 63251
    VCID: 60C4BC04CAC5
    No fault code found.
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul NDL 0517
    Coding: 00002
    Shop #: WSC 63251
    VCID: 356A3D5025C7
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 J
    Component: Airbag 8.4EP 1002
    Coding: 0010602
    Shop #: WSC 63251 000 00000
    VCID: 3E78227C10F1
    1 Fault Found:
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 R
    Component: Lenksáulenmodul 0801
    Coding: 01042
    Shop #: WSC 07155
    VCID: 4280568C6409
    5 Faults Found:
    01320 - Control Module for Climatronic (J255)
    49-10 - No Communications - Intermittent
    01304 - Radio
    01303 - Telephone Transceiver (R36)
    49-00 - No Communications
    01301 - Control Module for Voice Recognition (J507)
    01426 - Controls in Steering Wheel (E221)
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 900 M
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 00101
    Shop #: WSC 07155
    VCID: 2E58123CC091
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    53-10 - Supply Voltage Too Low - Intermittent
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 AT
    Component: Komfortgerát T23 1312
    Coding: 06976
    Shop #: WSC 63251
    VCID: 830E1388BB93
    Part No: 8E1959801B
    Component: Tőrsteuer.FS BRM 0103
    Part No: 8E1959802B
    Component: Tőrsteuer.BF BRM 0103
    Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0204
    Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0204
    6 Faults Found:
    00955 - Key 1
    00956 - Key 2
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    01333 - Door Control Module; Rear Left (J388)
    01334 - Door Control Module; Rear Right (J389)
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 L
    Component: concert II GRO 0001
    Coding: 01000
    Shop #: WSC 63251
    VCID: 30640C44DAA5
    1 Fault Found:
    07-10 - Signal too Low - Intermittent
    End ---------------------------------------------------------------------
  2. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    Clear all your faults, then scan again after a drive. Some of these codes will be old and not come back.
    The ones that come back will be the ones to look at.
  3. NHN
    29,351
    1,720
    Ditto, looks like battery been disconnected at some point.
  4. ludbe
    ludbe New Member
    what do you mean with that?
  5. NHN
    29,351
    1,720
    Usually with that many/those types of errors shown, the battery is either dying or has been disconnected in the past, as said, clear & check after a drive, then post repeat faults.
  6. Ekco163
    Ekco163 New Member
    25
    I had some of those codes on my car during last winter, I cleared them with VCDS, and they kept coming back. The battery was tested ok but seemed sluggish when starting, So I changed the battery and they all went away.:). The dying battery on mine caused the ESP to malfunction, so they can cause problems.
    HTH
