Audi A4 Tiptronic box lumpy running problem, please help !!!
moveitnick Feb 17, 2014
  1. moveitnick
    moveitnick Member
    32
    I am going to have a vagcom test done on the car this week. I have been having this lumpy acceleration and cruising speed problem when driving, it happens in tiptronic mode too. Someone said to me it could need a gearbox oil and filter change and that could solve the problem. I'm hoping i don't need the rather expensive gearbox sensor part which i think is around £800. Any advice is truly appreciated plus if anyone knows where is best to buy the gearbox sensor ? Many thanks to all.
  2. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,749
    165
    Can you explain more in terms of lumpy acceleration/cruising speed problem?
    Could be an issue with the engine rather than the box or maybe even a mount!
    However, an oil flush and filter change is wise on the auto box as Audi though longlife oil would last the life of the car/gearbox...hence the problems the earlier auto boxes had.
  3. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    which engine and which gearbox ?
    is it a tiptronic or is it a multitronic ?
    how many miles on the car ?
  4. moveitnick
    moveitnick Member
    32
    It is the 2.5 V6 diesel engine, multitronic with 114,000 miles on the clock. When it is driving it sometimes drives not smoothly, like when you barely touch the accelerator. Sometimes it drives fine. Many thanks
  5. p1tse
    p1tse Member
    797
    24
    You may want to chane the title
    Multitronic need regular maintaince oil changes
    Do a google search on it
    Try an oil service on it and fingers crossed fixes isues
  6. moveitnick
    moveitnick Member
    32
    Many thanks for the advice, just seen that the gearbox takes nearly 8 litres of CVT oil ! WOW !
  7. moveitnick
    moveitnick Member
    32
    CVT oil and filter ordered and being done on wednesday, hope that solves the glitch ! Will post back if it does the trick, thanks for all your advice peeps !
  8. shorty
    shorty New Member
    15
    Do the revs 'bounce' up and down slightly (100- 200rpm) at a constant speed? If so then it could be an issue with your torque converter. Google it and you'll find its seemingly a common problem with the tip auto boxes. I have it with my '04 S4. :-(
    Seems its not a cheap fix either.
  9. p1tse
    p1tse Member
    797
    24
    Tiptronic and cvt are different boxes
    First I've heard of s4 tiptronic issue though, will google
  10. dualmono21
    1,138
    Had this when i first bought my car
    Was nothing whatsoever to do with torque convertor ....
    It was due to too much differance between the rolling radius of the tyres
    Changed tyres and hey presto .... Cured problem nothing to do with torque convertor
  11. dualmono21
    1,138
  12. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,165
    1,124
    First check for fault codes with VCDS or other.
    That will show up any faulty sensors.
    If there is no fault codes, do the oil and strainer service.That will solve most of the issues.
    I got the simalaure fault with my Auto box and will be putting it in for a oil service when when I get time.
  13. moveitnick
    moveitnick Member
    32
    I had a problem last year with the autobox where it flashed PRDNS , i had that re-programmed to fix it but it has started again so it looks like i will have to buy the ecu which i think is around £800 !!!!! So if anyone knows of the best place to buy it , i will be very grateful !
