Audi A4 - Rear Light Bulbs Fault
amz Oct 4, 2012
  1. amz
    amz Member
    185
    Hi people,
    I am getting really fed up and frustrated with my rear light bulbs blowing out every other week literally!
    Is this a common fault? Is there a solution to this annoying problem?
  2. amz
    amz Member
    185
    Am I the only one with this fault then?
  3. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    Not had a problem myself. Sounds like too much current is getting to the bulb and burning it out which could only be an electrical issue.
  4. SmoothAssault
    SmoothAssault Will design for mods
    822
    53
    Sorry, probably a dumb answer but are you definitely putting the right bulbs in? They're dual filament aren't they? I imagine if you were putting single filament ones in, that might be causing them to pop?
    EDIT: Should be these I think...
    Bulbs: AUDI / A4 SALOON / 2004 (04)
  5. amz
    amz Member
    185
    Yes I've definitely put the right ones in but I get the same problem after a while.
    I've googled the same problem and there have been numerous threads...but no solution :(
  6. hades-
    9,481
    646
    my daughters A3 was blowing rear bulb every few weeks
    i used to get them from my pals garage
    i ended up buying 2 from halfrauds as we were away so had to buy them
    not had a prob sinse around 3 mth
  7. marktdisport
    marktdisport Active Member
    1,195
    15
    Buy a decent brand may be the answer
  8. amz
    amz Member
    185
    I'm hoping this might do it actually, fingers crossed!
  9. demus
    demus Fire in the hole..
    355
    19
    There can be big differences in bulb qualities, I put nice bright Philips and Osram bulbs in our Landy and it kept eating them, said sod it and bought two Ring lamps from the motor factor and they've been fine for about 3 years now, and just as bright...
