Audi A4 Quattro 2.8i V6 5v
bhainart Mar 17, 2010
  1. bhainart
    bhainart New Member
    25
    I would like some advice regarding an engine running problem I have started noticing. When the engine is cold from start-up the car pulls normally and will accelerate with all the haste expected of a 2.8i Quattro. However, when the engine has fully warmed up after a few miles it will shudder and behave like it has lost power. The engine never stalls and will quickly get back to it's normal running state after a few seconds.
    As well as the above I have noticed the smell of oil which is quite strong when the engine is hot and obviously there is a leak somewhere (possibly the head gasket?).
    A local Audi/VW mechanic has suggested that it is the ignition leads (apparently a known issue with Audi/VW/Skoda) and suggested that changing them will sort the problem.
    I have just had to spend over £500 within the past week replacing the ABS module and two new discs/pads etc for the MOT and I want to get any feedback from anyone who has a 2.8i and has had a similar problem before shelling out on HT leads to find that the problem has not gone away.
    Any advice anyone. Thanks in advance.
  2. Broken Byzan
    13,244
    468
    Leads or plugs breaking down when warm would be my guess from what you describe.
  3. bhainart
    bhainart New Member
    25
    Kind of confirms what the technician said which is good news as fairly cheap to put right. Thanks for that very much appreciated.
