Audi A4 flywheel on S3
lloydie1 Mar 4, 2012
  1. lloydie1
    lloydie1 Member
    68
    Anyone know if the A4 flywheel can be used on an S3? I have been offered a complete Helix setup cheap but I've read the A4 runs a slightly smaller diameter flywheel by 6mm. Would be nice to know if it bolts up. Ta
  2. adamss24
    adamss24 Well-Known Member
    4,561
    395
    nope, it won't fit as the ring gear is on the wrong side... You might be able to use the clutch plate but i'm sure the pressure plate is different...
  3. lloydie1
    lloydie1 Member
    68
    Sorry I don't get it - the starter is in the othe side but I thought the ring gear is in the same relative position on both flywheels?
  4. aragorn
    18,041
    728
    Nope, friction plate is different too, and the ring gear sits further away from the engine.
  5. adamss24
    4,561
    395
    Doesn't fit no matter how large your hammer is ! The s3/transverse flywheel has a different trigger for the crank sensor compared with the longitudinal engine...
  6. aragorn
    18,041
    728
    no 1.8T has its crank trigger on the flywheel, they're internal.
    Still doesnt make a difference though, it wont fit!
  7. lloydie1
    lloydie1 Member
    68
    Baah. Thanks anyway, looks like I'll have to pay top dollar for a new one then :(
