Audi a4 diverter valve
sewell10 Oct 30, 2012
  1. sewell10
    sewell10 Member
    236
    Hi there got a audi a4 2.0 tfsi dtm surposed to be remapped lacked power do I go for the standard valve or the updated valve any gen part numbers for my car thanks
  2. Pabs
    Pabs Active Member
    650
    54
    Forge 007p or the newer 008 which is a bit more expensive
  3. hades-
    9,481
    646
  4. razza1
    razza1 Well-Known Member
    3,075
    829
    Std Audi one, revision d is the uprated one
  5. sewell10
    sewell10 Member
    236
    is the revision d no good for my car
  6. hades-
    9,481
    646
    the rev D is fine
  7. sewell10
    sewell10 Member
    236
    Hello bez will I feel a improvment in the valve don't supose u have a part number fella
  8. hades-
    9,481
    646
    well if your old DV is nackered
    then fitting the rev D or even an older one you will feel an improvment
    but if the old one is ok then no
    remove and inspect if its ripped then change if not i wouldnt bother.
    i have 1 at the yard if u you need 1.
  9. sewell10
    sewell10 Member
    236
    Thxs bez is that a standard valve u have when I give my car a good throttle full after 3500 up over holds back and boost cuts goes into limp mode for a while then ok
  10. hades-
    9,481
    646
    yeah i have a rev D with around 3/4 K on it
    sounds live it could be the dv
    just whip it of and have a check half hour job.
