Audi A4 Cruise Control Retrofit problems
DTM_Dan Feb 17, 2013
  1. DTM_Dan
    DTM_Dan New Member
    21
    Ok - very new to VCDS having opted to buy it.
    I recently retro fitted a MFSW & Cruise control to my 55 A4 DTM. Good news is that the MFSW works great. However the Cruise control doesnt. I have two issues, 1) steering angle setup and 2) I cannot login to section 11 under 03 ABS brakes. it is ghosted out and says coding. I may have done something wrong here, i'm not sure. Also once i do get in to this login the DTM brake code is not listed when creating the login code.
    As a result i have the ESP light on the dash - and i am guessing no ABS.
    logs:
    Saturday,16,February,2013,10:00:25:62907
    VCDS Version: Release 11.11.5
    Data version: 20121222
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    Address 03: ABS Brakes Labels: 8E0-910-517.lbl
    Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
    Component: ESP8 quattro H05 0120
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004526
    Shop #: WSC 06335 000 00000
    VCID: 2953CA32800C9950562
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 22
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4222
    Hex Value: 0x001E
    Hex Value: 0x3E8F
    Hex Value: 0x0001
    Any help gratefully received. I have tried the process ofr re-calibraing the sensor - but with no success.
  2. NHN
    29,284
    1,695
    Well thats what you need to do, calibrate the sensor, what process are you following?
  3. DTM_Dan
    DTM_Dan New Member
    21
    Turn steering wheel at least 30 ° left and back straight ahead.
    Select [Meas. Blocks - 08]
    Enter Group 005, [Go!]
    Field 1 (Steering Angle Sensor -G85-)
    Specification: 0.0 °
    Tolerance (when straight): ±5.0 ° (Note - When the steering wheel is straight the value shown
    should be -5 - +5 degrees, set it in between these values and leave it there for the rest of the
    procedure)
    Select [Done, Go Back]
    this was taken from an online guide - have also followed the Ross Tech guide but when it says login 11 - 40168 my login says coding (ghosted out). and i cant go any further.
  4. DTM_Dan
    DTM_Dan New Member
    21
    right - managed to reset the steering angle sensor and fault gone - missed the step where you have to start the engine!
    however for the cruise control coding, i have coded the steering wheel - 16 (02041) and have coded the engine - 01. I had to use long coding on this as it had "coding II - 11" ghosted out. But when i go to code the ABS - 03 the "coding II - 11" is ghosted out so i cannot input 40168. Any ideas?
    I addition for the step where you are meant to go into ABS - 03, function - 07 and enter the code i get 04X75 however the brakes on the DTM are listed as 1LC which isnt listed under the options for byte 3? any ideas?
    thanks in advance
  5. NHN
    29,284
    1,695
    If I was you I would ping an email to support@ross-tech.com if you've registered your cable & advise of this query as it may help update the coding for later people stuck on the same issue.
  6. Penninepete1
    Penninepete1 New Member
    14
    Did you make any progress on this?
    I have the same issue whilst trying to retrofit CC, I have coded the steering wheel and engine and calibrated the steering wheel sensor but cant get in to code the brakes because the Login - 11 box is greyed out under 03 - ABS Brakes.
    Im going to email ross tech today to see if they can help.
  7. Penninepete1
    14
    All sorted :yes:
    It was the clutch switch that had failed so the cruise control wouldnt work, nothing to do withmy coding!
    Interestingly Ross-tech said there is no need to re-code the ABS module when doing a cruise retrofit, yet every guide I have seen on the net says that you do!
  8. NHN
    29,284
    1,695
    Never once had to recode anything in abs, only steering angle sensor calibrations, so by that I agree with RT completely.
