Audi A4 Convertible/Cabriolet roof problem and possible solution
NickRB Jun 26, 2012
  1. NickRB
    NickRB New Member
    Hi,
    I recently had a problem with the roof slowing down and eventually stopping on my A4 Convertible. I consulted the forum and came across an excellent article from Krumz in relation to cleaning the hood motor. Link to the article as below:
    http://www.audi-sport.net/vb/audi-s...et-soft-top-roof-hood-motor-repair-guide.html
    I followed this article and did exactly as described but unfortunately this did not cure the problem. In the article was a link to a chap on Ebay who rebuilds motors so I got in touch with him as he was fairly local to me. Link below:
    Audi A4 Cabriolet Roof Motor Repair (Power-Packer) | eBay
    In short while the A4 was in to the local main Audi dealer (York) for a cambelt change I asked them to diagnose the hood fault and was told I needed a new pump which would be £1200 plus!
    When speaking to Mervyn (Ebay chap) I described the symptoms of the hood not working and he immediately confirmed it was a motor fault as the original brushes fitted to the motor are of poor quality. He also advised that rarely do the pumps fail and that he had reconditioned hundreds of motors.
    I visited Mervyn and within half an hour he had cleaned the bushes up and confirmed the motor was working fine. This did the trick but the hood still struggled which was down to the pump not having enough hydraulic oil in the reservoir. Topped up the oil and the hood now works perfectly.
    The article from Krumz was spot on and very comprehensive. Mervyn is very helpful and his contact number is in the link. He does a very quick mail order service for your motor as described in the link.
    Overall this solution cost me £30 for Mervyn to clean the motor (I had already removed the trim to gain access) and £8 for a bottle of hydraulic fluid from Audi. Total £38 as opposed to £1200 plus from Audi!!!
    Do not have faith in main dealers, they mis-timed the new cam belt when fitted and the car had to go back to be set up properly and on a health check they completely misssed a tyre that was illegal on the inside despite them stating it had 5mm!
    Hope this post helps as the links saved me a fortune.
    Thanks again to the forum, Krumz and Mervyn
    Nick[​IMG]
    JLBmatic likes this.
  2. bowen
    bowen Member
    466
    20
    Thanks for this, very useful!
  3. rjm180
    rjm180 Active Member
    581
    34
    Very useful info indeed. Many Thanks and good to hear of a nice result. Any pics of your cab?
  4. turkonboard
    turkonboard New Member
    17
    Brilliant brilliant brilliant!
  5. jkmb
    jkmb New Member
    Thanks for this. I had a similar fault, removed the pump motor and sent it off to Mervyn at Autoelectron (very helpful over the phone as well), received it back a couple of days later and happy to say all working fine now.
    So, thanks for this post, thanks to Mervyn and hope this helps anyone else.
    If you think you may have the similar fault, check out:
    J
  6. abstein
    abstein New Member
    Sorry to bump up an old thread, but I am having the exact same problem described here with my 2009 A4 Cabriolet. As much as I would love to visit Mervyn in Yorkshire, I am located in Los Angeles, California.
    Has anyone heard of anyone who does this repair in California? I wrote to Mervyn too... Any advice is much appreciated.
  7. leegsi
    leegsi Active Member
    489
    57
    I think there is a guy on here that will sell the brushes to you so you can strip the motor down.
    There is a big thread about it.
  8. VagPro
    VagPro Active Member
    449
    35
    Hi all,
    yes I have finally managed to reverse engineer the brushes and carriers and a kit is available on eBay.
  9. leegsi
    489
    57
    Any links?
  10. Ovid
    Ovid Active Member
    291
    35
    Any good electric motor company sells them for pennies.
  11. VagPro
    449
    35
  12. Samuel1993
    Samuel1993 New Member
    I had a problem with my Audi A4 Convertible roof with only the front opening a few inches then stopping there. I tried over and over and it kept getting stuck in the same position. I thought there was a problem with the hydraulic motor that functions the roof. Therefore looked on YouTube to find someone who had the same issue and resolved it by taking out the motor and cleaning the brass brushes inside of it.
    I went to the effort of doing this which all in all took me around about an hour to do.
    I put it in back correctly after cleaning it all to find the problem still occurred. I then thought it could be the relays on the motor which weren't working properly.
    Before I tested the relays I found out from a friend that you can do a manual reset which could resolve the issue.
    To manually reset the roof you must open the fuse box to the side of the driver's side panel and take out the Red Roof Key. Then have your car key in the ignition and switched in the on position (not engine start position). Then put the Red Roof Key into the slot located on the interior roof behind the interior light switch, turn they Roof Key and the front of the roof will unlock. Step out the car and pull back the front of the roof and lift up the back (2 people required), you can then access the roof hatch where it stores, jump in the back of the car and pull out the middle compartment between the rear seats and inside there is another slot for the Roof Key above. Put the key in and turn until roof hatch unlocks and pops open, then open and pull the hatch back and place the roof inside. Once the roof is in, relock the hatch by putting the Roof Key inside the slot again and turning the opposite way. After this is done do this method I'm revers until the roof is back up and locked in position using the Roof Key locking from back to front. Once all locked the roof programming has been reset. Turn on the engine and operate roof switch and the roof should function normally.
    It completely surprised me that this worked as thought it would be down to some sort of mechanical problem costing hundreds. I had tried this method previously just to to try to see if would operate but I didn't put the car key in the ON POSITION (this is very important to reset the roof otherwise will not work. The whole procedure will only take 5 minutes and works wonders.
    Hope this helps anyone with a roof problem for their Audi A4 Convertible.
