Audi A4 Cabriolet Soft Top/ Roof / Hood Motor Repair Guide
VagPro Sep 25, 2011
  1. olbyrne
    olbyrne New Member
    Thanks VagPro, I've been putting up with an intermittent roof opening/closing for 6 months until I came across your very clear instructions/photos re cleaning Motor Commutator etc. In fact hardest part was replacing the side panel and alligning the grommet holes etc.
    Thanks again
    VagPro likes this.
  2. pez5918
    pez5918 New Member
    9
    Hi , yes housing marked up , noticed today when taken manually down it will raise on auto an inch then stop also same as front,motor still audible at rear
  3. VagPro
    VagPro Active Member
    449
    35
    Hmm that's interesting, was the motor audible before you cleaned the commutator ?
    what fault codes are you getting ?
  4. nedfp
    nedfp New Member
    Ok, so in my rush, I skipped the brush prying and spring action check. So, I get the roof working and I think life is great. Just saved $650 from Audi of Tysons, VA. They quoted new motor. This after passing the 50K and 48 months by 2 mos. and 100 miles. They offered $100 off the new motor and nothing on labor.
    Long story short, the motor worked great for 3 weeks, and then fail. Repeated the cleaning (used rubbing alcohol too) and nothing. Checked the brushes, and I am sitting pretty.
    Now if I could only find a cheap VAG COM cable for my 09 a4 cab. Any ideas? Love to be able to write so I can activate my AUX on the symphony II+.
  5. VagPro
    449
    35
    you are "sitting pretty" ? Is the roof not working ? Make sure the brushes are making contact with the commutator. You HAVE to pry open the brush carriers
    vagcom cables eBay or NHN on the forum
  6. pez5918
    pez5918 New Member
    9
    No the motor was inaudible till a good clean , now audible and will raise the rear in auto to close but stops after an inch , I'm thinking maybe hydraulics ? Not got fault codes as yet as no cable etc , trying to obtain one or take a trip to local garage
  7. nedfp
    nedfp New Member
    Sitting pretty = the roof operates as expected. The issue has been resolved. The point of the reply was to stress that in my haste to complete the cleaning, I did not check the brushes. It was the culprit. I am admitting to my stupidity so that others may learn that the brush checking is vital to the DIY.
    I am do wonder if I should have added a lubricant to the brushes though.
    A friend who lives next door, who is a chemist for Mobil, gave me some "product" (red lithium grease) for the top of the spindle as suggested. Also allowed we to sample some M1 0w-40 for my next oil change. Shame, I just did my first extraction last weekend (mityvac 7201) and refilled with Rotella T6 5w-40. Off topic - I know.
    I did get a cheap K+CAN cable from ebay. Can't verify it works as VAG Commander and VCDS do not recognize it. I guess I need to do more research/buy another. I bought a Bluetooth elm-327 reader that works great, just can't write.
    VagPro likes this.
  8. pez5918
    pez5918 New Member
    9
    Managed to aquire a Bluetooth code reader thingy which is reading no faults , I know it works because its picking up one on the wife's A3 so still stuck
  9. nedfp
    nedfp New Member
    Ended up getting a true Ross-Tech VAG COM scan. Had 2 codes for the roof cleared:
    02000 - Switch Position
    008 - Implausible Signal
    Went on 40 mile top down cruise in sunny 85 degree weather. The joy of owning a Cabriolet!
    Aux is now work - I'll post the wiki.
  10. VagPro
    449
    35
    happy days, don't worry about those codes they won't come back as they get generated after manual operation
  11. VagPro
    449
    35
    No codes..... Hmmmm can you access the roof module from your code reader ? Is it using the same protocol as vcds or is it a generic obd2 reader ?
    Is your wife's a3 a cabriolet ? And can you acess the roof module using your reader ?
  12. pez5918
    pez5918 New Member
    9
    Its a generic obd2 reader , the wife's is not a cabriolet , going to have another play , how you fixed Fri for a visit lol
  13. VagPro
    449
    35
    you need vcds, you can't access the roof module with obd2. Available in the evening....
  14. pez5918
    pez5918 New Member
    9
    Think ill pay you that visit before I tear the rest of my hair out , how you fixed wed eve ?
  15. VagPro
    449
    35
    Lol no problem at all, I'm busy wed. Does today work?.. (Taken a day off from the office)
  16. pez5918
    pez5918 New Member
    9
    I'm in Staffordshire so a trip down the a50 and I can be with you in an hour if you Dnt mind
  17. VagPro
    449
    35
    Perfect lets do it, phone number on my facebook page
    Facebook.com/vprouk
  18. pez5918
    pez5918 New Member
    9
    Would just like to say a massive thankyou to VAGPRO for the assistance , roof is now in perfect working order , and the trip to Leicester well worth it lol .
  19. olbyrne
    olbyrne New Member
    Hi VagPro, After cleaning the Commutator etc as per your instructions the roof worked fine for a couple of weeks and then same issue as before ie roof raises an inch and stops. I cleaned the Commutator again and all works fine again though I suspect one of the brushes does not spring back as easily as the other brush.
    Any suggestions on how to loosen a brush to enable it to make contact with the Commutator on its own accord?
    Thanks again
    Ol
  20. VagPro
    449
    35
    Hi Ol,
    Definitely got to be sticking brushes, you need to pry open the carriers to free them up. (Be gentle)
  21. simon.price
    simon.price New Member
    VAG PRO -- Bristol Audi quoted £2,600 for a new hydraulic motor after reviewing my intermittently working roof. Other dealers said the problem was more likely the motor and quoted £370-£400. Following your excellent instructions the roof has now been working perfectly for 2 months. I think sticking brushes was the main fault and easing open the holders was probably made the difference. Thanks for saving me £2,600 and beware main dealers!
    VagPro likes this.
  22. 27mart
    27mart New Member
    Hi VagPro,
    Thanks for this guide, the motor was originally not making any sound when I came across this comprehensive repair procedure.
    Having followed the procedure the roof unlatches and I can NOW hear the motor but roof still fails to move any further.
    This appears to be the same issue as that experienced by pez5918 above. Is there a quick fix for this, I have access to vcds.
    Regards
  23. VagPro
    449
    35
    Hello,
    Did you mark the rotor bell housing when you took it off and are sure you have put it on the same way?
  24. 27mart
    27mart New Member
    Hi. Erm I did not mark the housing cover. It can only be mounted in two positions in order for the bolt holes to line up. Do you think turning the housing cover 180 degrees will make a difference then?
  25. VagPro
    449
    35
    I know turning the cover 180 degrees will make a very BIG difference :)
  26. 27mart
    27mart New Member
    Ok I will try that later. Thanks for the prompt reply by the way. Cheers
  27. 27mart
    27mart New Member
    Top marks vagpro. I have rotated the motor housing as suggested. Roof now operates up n down. Many thanks for this guide. :D
    VagPro likes this.
  28. Kjm2304
    Kjm2304 New Member
    Hi
    I too have probs with my roof and today booked it in at Audi they said maybe pump and cost £1800 for pump?.. My car is 2007 a4 may I ask as I also live in Leicester if you could probably check it for me happy to pay you. They charge £98 to diagnose and know its rip off place. Many thanks Kerry
  29. VagPro
    449
    35
    Hi Kerry. Responded to your pm. Regards
  30. Kjm2304
    Kjm2304 New Member
    Thanks message on this site? Can not see it?
    Kerry
  31. Kjm2304
    Kjm2304 New Member
    Cheers will ring you tomorrow
  32. VagPro
    449
    35
    No problem, I'm a bit tied up in the morning so afternoon is fine. Otherwise fell free to call now if convenient.
    Regards
  33. Smithk77
    Smithk77 New Member
    Hi All,
    I have the same problem as most of you however I have cleaned the motor as above and still have issues.
    mine started when I took my roof down and my battery then died on my car (long period standing still) I managed to fit a new battery but my roof would then not come back up so I manually bought it up. What I did forget to do was lock the hood cover down and just fastened the front roof clips. Only on driving did I notice the noise and then locked the cover down.
    now I can retract the roof no problem but when I try and bring it up nothing happens period. Roof does not unclip, roof cover does not unclip and no noise from my motor.
    I've not checked any codes as of yet as I don't have access to the software.
    im going insane with this car as not only has this happened but my tcm has just started playing up....!
    thanks in advance for any help
  34. VagPro
    449
    35
    Hi Smith,
    When you cleaned the commutator on the motor, did you check the brushes if they are moving freely? Also did you pry open the brush carriers ?
    In regards to the problem you have now, I think you already know that you need to get access to a VCDS cable and take it from there. Let me know when you have the fault codes...
  35. Smithk77
    Smithk77 New Member
    Hi vagpro,
    yeah I pried open and done everything exactly as stated. Gotta get my car serviced so may ask them to check and give me the codes.
    I'm thinking of buying the cables from eBay for future help. My car is a 56 plate 2.0 fsi auto. What do I need to ensure the cables can do so it supports my car?
    cheers,
    kieren
  36. jimrob
    jimrob New Member
    VagPro you are indeed a PRO at this and thanks for posting all this information up. Hopefully you can help me out with my 2007 Cabrio roof issue. My daughter had my car while I was away on vacation. She put the roof down and it wouldn't go back up. The lid would unlatch and that was all it would do. She went online and found out how to manually close it. When I got home the roof would unlatch and that was all. The motor was not running. I took it out and cleaned the armature and made sure the brushes were free. The motor works fine now. The roof only unlatches when open or closed. When closed it opens up just beyond the latches. The motor can be heard running and the second bar back starts pushing downwards towards the car instead of the front going upwards. I have cycled the roof manually open and closed with the key on to reset the switches. It still does the same thing. The roof indicator light flashes 10 times when the key is turned on. Do you know what this means? I do not have a VagCom setup. My nearest dealer is 15 miles from me and not liked very much by the average person because they raise the prices on parts over the MSRP of Audi. I wish you were 10 miles from me instead of my living across the pond in the US.
    Jim
  37. VagPro
    449
    35
    Hello Jim,
    Thanks for the very informative post, always helps when I have all the information. Sir, you have got the rotor bell housing on 180 degrees out, did you mark it before you took it off?
    Regards
  38. VagPro
    449
    35
    Hi Kieren, not sure as I have the tulle version. but you can pm NHN on this forum as he's a retailer and will be able to shine some light on it.
  39. jimrob
    jimrob New Member
    I did not mark the bell when I removed it. I'm heading out right now to switch it around. I will post what happens afterwards.
    Thanks,
  40. VagPro
    449
    35
    I bet you any money that your next post will be saying the the roof is working :)
