Address 01: Engine Labels: None Part No SW: 8E0 909 552 N HW: 8E0 909 052
Component: 2.4L V6/5V 0004
Coding: 0011584
Shop #: WSC 00672 785 00200
VCID: 397D29D70C7D
7 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 008 - Implausible Signal - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 008 - Implausible Signal - Intermittent
18034 - Powertrain Data Bus: Missing Message from TCU
P1626 - 004 - No Signal/Communication - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
17546 - Fuel Trim: Bank 2 (Add): System too Lean
P1138 - 001 - Upper Limit Exceeded - MIL ON
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 001 - Upper Limit Exceeded - MIL ON
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No: 01J 927 156 DB
Component: V30 01J 2.4l 5V RdW 3031
Coding: 00001
Shop #: WSC 04940
VCID: 6FE9D78F02B9
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1729
Coding: 04499
Shop #: WSC 00672
VCID: E5C535A75045
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 K
Component: A4 Klimaautomat 1116
Coding: 00100
Shop #: WSC 00672
VCID: 295DF997FCDD
3 Faults Found:
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
30-10 - Open or Short to Plus - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
41-10 - Blocked or No Voltage - Intermittent
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 00672
VCID: 346318E32B1F
1 Fault Found:
35-00 - -
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655 B
Component: Airbag 8.4EC 1015
Coding: 0011104
VCID: 397D29D70C7D
2 Faults Found:
00474 - Control Module for Immobilizer
000 - - - Intermittent
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 01111
Shop #: WSC 00672
VCID: 3E773ACB1553
1 Fault Found:
35-00 - -
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 980 F
Component: KOMBI+WEGFAHRS. RB4 D16
Coding: 00401
Shop #: WSC 01120
VCID: 326F1EFBD10B
Subsystem 1 - Part No: 20288
Component: AUZ6Z0B0367027
20288 AUZ6Z0B0367027
4 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to Plus
29-00 - Short to Ground
27-10 - Implausible Signal - Intermittent
01302 - Control Module for Telematic (J499)
49-00 - No Communications
Address 37: Navigation Labels: Redir Fail!
Part No: 8E0 035 192 B
Component: RNS 4.2 H06 BNO 0102
VCID: 2341EBBF9EF1
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0311
Coding: 00001
Shop #: WSC 00000
VCID: EFE9578F82B9
1 Fault Found:
01350 - Alarm via Theft Warning System; Rear
43-00 - Closed
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8H0 959 433 D
Component: Komfortgerát T3B 1210
Coding: 06827
Shop #: WSC 00099
VCID: 356525E72065
Subsystem 1 - Part No: 8H2959802
Component: Tõrsteuer.FS BRM 0001
Subsystem 2 - Part No: 8H2959801
Component: Tõrsteuer.BF BRM 0001
Subsystem 3 - Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0001
Subsystem 4 - Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 1.60
5 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
00935 - Electric Window Motor; Rear Right (V27)
62-10 - No or Incorrect Adjustment - Intermittent
Address 56: Radio Labels: Redir Fail!
Component: Radio BNO 0001
Coding: 00017
Shop #: WSC 00099
VCID: 2341EBBF9EF1
1 Fault Found:
00856 - Radio Antenna
44-00 - Short Circuit
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 01105
Shop #: WSC 00672
VCID: 43814B3F7EB1
End ---------------------------------------------------------------------
