Audi A4 Cab 2006
Timmy May 15, 2011
  1. Timmy
    Timmy New Member
    Hi all
    I have recently purchased my Audi and had a few problems, there was a judder when pulling away which was diagnosed as a faulty dual mass fly wheel which subsequently has been replaced. During the same time the DPF warning light came on and Audi fixed this by regeneration.
    My questions are:
    How long does the regeneration period last?
    Is it worth removing the DPF and at what cost?
    Do other forum members have the same issues?
    Thankyou in advance
  2. arnoldlog
    arnoldlog Member
    59
    I drive a 2.0tdi 2008 cab and I recently had my clutch and DMF replaced(after 30k), this seems to be a common problem. DPF - regeneration lasts around 5 - 10 mins in mine when driving at the right conditions. dpf removal is quite costly I believe around £1k, not something I have looked into tho so maybe someone will give you a more acurate price.
  3. Timmy
    Timmy New Member
    Thank you arnoldlog. Do you use yours for short journeys?
  4. arnoldlog
    arnoldlog Member
    59
    generally yes, its just a short 7 mile trip to work everyday, its dual carriageway but its all stop start. I've owned the car for about 15 months now and the regen dpf has come on about 5-6 times during that time, which i dont think is too bad. what i have found tho is that it comes on, I do the regen procedure 2 weeks later the lights back on again, then i wont see it for months.
  5. Timmy
    Timmy New Member
    One last question.
    How do you do the regeneratin procedure?
    Do you drive at a certain speed in a designated gear.
    I had my generation done at Audi under the warranty so that is the reason I am asking.
    Thank you once again
  6. arnoldlog
    arnoldlog Member
    59
    4th or 5th gear for 10 minutes with engine speed around 2000rpm
  7. Timmy
    Timmy New Member
    Thank you for your promt answers... Happy driving
  8. cee-gee
    cee-gee New Member
    Hi
    Just had dual mass fly wheel & clutch replaced on my cab, £1200 pound from vag approved garage, main dealer was far more.
    Drives like a new motor now!! If it is the DMF you are taking a risk if you leave it as the result can be costly.
    Craig
