For Sale Audi A4 B7 TDI S-Line 2005 Show Car Modified Air Ride (DTM,RS4,US,Bentley Parts)
D2NY G May 21, 2015
  1. D2NY G
    D2NY G Well-Known Member
    1,088
    132
    [​IMG]$_57 by Danny Gee, on Flickr
    http://www.ebay.co.uk/itm/201348239709?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
    £8,200 ono, will listen to offers
    I have owned this car for 4 and a half years, in this time the car started out as a fully standard s-line model A4 and now it is the car you see in the pictures.
    The car has never wanted for anything, over the years it has been regularly serviced and always kept clean just as they should be! Will be sad to see it go
    It has gone through various changes with being used as a show car for the last few years finally I got the look I was after and now its time to move on and let someone else enjoy it
    The car has a 128,100 miles on the clock (as of 11/05/15), but the engine was replaced at 119,090 miles as on the old engine the turbo went and me not stopping in time caused all the oil to be taken from the engine resulting in it seizing :(
    So the cars current engine has just slightly over 9k miles on it its basically still brand new, I decided to go for a BLB engine that had the uprated oil pump just for my peace of mind, along with the new engine it has obviously had a new turbo unit, once removing the old engine I found the clutch and fly wheel was on the way out, so whilst it was all being rebuilt I had a new clutch and dual mass flywheel installed, it cost a fortune but it needed to be done I had took the car this far I couldn't let a blown engine stop me. Along with the engine replacement it was treated to all new seals, slave cylinder, timing belt, water pump basically everything I could think of doing. The work was all undertaken by an audi specialist, and all paper work for the engine is in my folder, the clutch, flywheel & turbo unit are still under warranty.
    The whole engine replacement / work ect was carried out in June-July 2014
    The car is a dream to drive the airlift air suspension is great giving it a smooth ride even with the 20" Bentley wheels on it
    The Audi is MOT'd till Feb 2016 it went straight through with no advisories
    The last picture is an example of how high the car can go when you set up the air suspension
    Here is a run down of the cars specs with descriptions
    Engine & Exhaust
    Rebuilt Engine (@119,070 Engine, Turbo, Clutch & Flywheel, Timing Belt, Water Pump, Slave Cylinder, New Seals) As mentioned above
    Revo Remap Done By Statller In Sheffield (Currently running 193.8 BHP & 289.7 Ibft - With dyno graph to prove)
    Genuine Audi A4/RS4 Optional Engine Covers Painted In Piano Black
    Air Intake Painted In Piano Black
    Custom Fuel Filter Cover Painted In Piano Black (Made from a Pug 206 suspension top cover - perfect size to cover the fuel filter as I found)
    Coolant Bottle Painted Black
    TDI Engine Cover Painted In Quartz Grey With Carbon Fibre Dipped Raised Section (Done by Hydro Precision)
    Genuine R8 Oil Cap
    Genuine Porsche Coolant Cap
    Audi Logo Custom CNC Washer Bottle Cap
    Custom Hidden Exhaust (This was done by removing the exhaust tips and shortening and down turning enough to clear the smoothed rear diffuser)
    All the usual S-Line refinements 6 Speed gearbox, alarm immobilisers, dual climate control ect
    Wheels & Tyres
    20” Genuine Bentley Mulliner (9J ET41)
    Black Powder Coated Dishes & Barrels
    Quartz Grey Faces
    Black Bentley Ring
    Quartz Grey ‘B’ Badge With Black ‘B’
    Genuine Bentley Dust Caps
    225/35/20 Tyres (With plenty of tread left no camber wear as I had it 4 wheel laser aligned)
    Suspension
    Air Lift V2 Air Suspension (Fitted by LowStandards)
    Front End Inner Arch Notch (Doing this on the B7 chassis give you approx 15-20mm extra drop on the front)
    Brakes
    M-Tec Drilled & Grooved (All Round)
    Mintex Pads (All Round)
    Painted Red Calipers (All Round)
    Body
    Genuine DTM Front Bumper With Genuine Carbon Splitter (Getting really hard to come by now these)
    US Spec Plinth (Will include normal mount so you can have the number plate on the front if preferred)
    Custom US Spec Style Boot (Shortened recess ideal for shorter number plates)
    Custom Made Smoothed S-Line Rear Diffuser (Using the sline single exhaust splitter and plastic welding and smoothing over the exhaust gap, to the best of my knowledge this is the only one running this modification)
    Carbon Dipped Window Plates (Done by Hydro Precision)
    Clear Corner Headlight Mod (Removing the orange indicator lense, then fitting sliver tec indicators)
    B8 Style Smoked LED Rear Lights
    Interior
    All the interior was re trimmed by MB-Trims in Doncaster who specialise in classic cars and have done a fantastic job
    Custom Re-trim Half Leather & Quilted Alcantara With Red Stitching
    Quilted Alcantara Door Cards With Red Stitching
    Quilted Alcantara Armrests With Red Stitching
    Alcantara Gear Gaiter With Red Stitching
    Black Interior Trim + Panels
    Carbon Dipped Fibre Interior Trims (Done by Hydro Precision)
    Custom V2 Air Ride Controller Mount Carbon Fibre Dipped (Done by Hydro Precision)
    Genuine Bentley Gear Knob
    Genuine RS4 Pedals
    S-Line Steering Wheel Perforated Leather Red Stitching (From Cab A4 V6)
    Double Din Head Unit OEM Look With More Features (DVD player, SAT NAV, AUX-in, Bluetooth with microphone mounted on steering column, Micro SD card reader, Internal Hard Drive so you can copy music to it)
    Air Install (Half sunk 5 gallon tank with viair compressor built into spare wheel well) (will come with the spare wheel as well)
    Recent Work
    New front brakes as mentioned above with new pads (March 15)
    New rear brake pads (March 15)
    New drivers front wheel bearing (April 15)
    New passenger rear wheel bearing (March 15)
    Bits To Mention
    As with all cars there will be stone chips on the front end nothing major this is a 2005 car after all
    There is a very small laquer peal on the rear door aswell as a car park ding on the rear passenger door (multistory and no spaces far away from anyone!) both are no bigger than a 5p coin
    The rear LED lights on the passenger side have a few LEDS which are out in all fairness its not too bad passed MOT fine as it was not the full light
    Private plate is NOT included in the sale, currently waiting documentation from the DVLA for moving my plates across, the car will come with the standard 05 registration, this is why in the pictures there is no plate as its ready to be put on my new car
    And that is about everything! Nothing missed out!
    I have a full folder of receipts and paper work for the car including all maintenance work carried out and the modifications, which will be passed on in the sale
    With this I have a full history of pictures of the car through its various changes and all show coverage (can be supplied on a memory stick wit the sale if interested)
    The car is listed on various pages around the internet and social media so can be removed at anytime, so don't miss out!
    As mentioned before the mileage is 128,100 as of 11/05/15 (this will not rise as the car is now in a secure storage facility until the sale is complete)
    OPEN TO SENSIBLE OFFERS!
    Optional to remove the wheels to lower the price if requested, the air ride will not be taken off though
    NO TIME WASTERS!
    No insurance no test drives! I will take you for a drive if no insurance is shown
    Viewing can be arranged
    Based in Sheffield
    Call Danny on 07800970965 (if called during week and I don't answer I will be at work but text to arrange suitable time to call)
  2. tomtheblade
    tomtheblade New Member
    17
    If u decide to break it pal let me know would love airlift and Bentley only from Aston you've probably seen me about have my a4 dipped white back Grey now
  3. D2NY G
    1,088
    132
    Hey up fella, yeah I have seen that round the village, if a do decide to break it there will be a hole load of parts up for grabs ill deffo let you know.
    New ebay ad, old one ran out
    http://www.ebay.co.uk/itm/201354748120?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
  4. D2NY G
    1,088
    132
