Audi A4 B7 Front Axle Load
Ryan_Hol Feb 25, 2012
  1. Ryan_Hol
    Ryan_Hol Member
    121
    basically the website that i'm trying to order some coilovers off only gives 2 options :
    max front axle load 1080kg or Front axle load 1080 to 1220
    I am unsure of which my car is, its a 2006 A4 S-Line Special Edition 2.0Turbo FWD
    Any help appreciated, thanks
  2. Ryan_Hol
    Ryan_Hol Member
    121
  3. viceroy
    viceroy Active Member
    284
    76
    the usual choices are between FWD or quattro. Seeing as though you have FWD, I would guess the choice for you would be max 1080kg
  4. Dazmo
    Dazmo Active Member
    1,762
    Best thing is to ask them before ordering then at least you should get the correct ones.
    However viceroys theory is sound, usually quattro is the heavier load!
  5. Ryan_Hol
    Ryan_Hol Member
    121
    No problem thanks
  6. Jeeves
    Jeeves quattronly
    116
    There's a plate either on the engine bulkhead or B pillar or boot which shows weight of each axle. Its also handy for knowing the minimum Load Index you need for your tyres. Was a while ago when i looked for mine so can't remember which location i found mine in, but can remember I needed at least a 91 load index tyre on my diesel quattro avant. A lookup on that points to 1230kg, but that's for a diesel.
  7. Ryan_Hol
    Ryan_Hol Member
    121
    Right basically there's the VIN number then underneath:
    2005kg
    3450kg
    1 - 1090kg
    2 - 1045kg
    thanks
  8. Ryan_Hol
    Ryan_Hol Member
    121
    does this mean number 1 is front axle load?
  9. bigrich690
    bigrich690 Active Member
    553
    44
    the front will be heavier without a doubt, the engine is there...........unless you have put the engine in the boot lol
  10. Ryan_Hol
    Ryan_Hol Member
    121
    what i was asking is the 1 and 2 your axle loads or something else
