Audi A4 B6 Passenger Door Has No Power and Door is Stuck Shut Help!!!!!
Dean Mancell Aug 23, 2012
  1. Dean Mancell
    Dean Mancell New Member
    Hi, My audis passenger is is stuck shut, has no power to the lock, window or electric mirror and I cant even open it to check the wiring joint in the door. Is there a back up way to open the door at all or am I screwed?
    Thanks for any help, i will reaaaaalllly appreciate it, thanks Dean
  2. quattrojames
    14,050
    575
    You're not screwed.... but you will need to try and force the door card off from the inside, hopefully you'll be able to get enough of the card away to enable you to pop the catch open. It does sound like the wiring is damaged at the hinge point. Good luck.
  3. Silky
    Silky Member
    51
    Morning,
    I didn't want to start a new thread so did a search and found this.
    My B6 Avant has the same problem.
    Passenger rear is stuck shut. At the weekend all the doors would lock/unlock apart from the NSR. I then managed to get it to lock but then failed again to re-open. To make matters worse I have the child lock on so cannot be open from inside either.
    I believe it's the wiring which has failed, making it not unlock or open.
    Is there anything I can do to get it to open?
    Is going into Audi next week but want to give something a go myself
    Michael
  4. Silky
    Silky Member
    51
    I took out the 4 screws from the doorcard yesterday, then tried to get the doorcard off, but with the door being shut I just could not get my fingers round it enough to pull it.
    I then noticed I could access the wiring loom from outside the car at the bottom of the B pillar. I pulled back the rubber sleeve but could not see any damage to the wires. It could well be damaged further inside or at another part of the loom.
    Any ideas how you'd get the door undone when the child lock is on?!?!
  5. Silky
    Silky Member
    51
    Well it's going into Audi today to see what the problem is, bound to cost me plenty of £££'s
    Will report back with their findings
  6. Silky
    Silky Member
    51
    Split wires in the B Pillar, as expected.
    No idea how they managed to get the door undone but they have.
    £101.20 all in for the repair
  7. quattrojames
    14,050
    575
    Sounds pretty fair to me!
    I'd be interested to hear how they did it.
  8. demus
    demus Fire in the hole..
    355
    19
    Me too, probably not much more than an hour or two's labour in all honesty, so didn't take them long...
  9. quattrojames
    14,050
    575
    Most dealers charge in excess of £120 per hour....
  10. Silky
    Silky Member
    51
    Car was in at Audi Colchester, used them quite a few times now and always seem very fair.
    They were working on the car for about 3hrs or so, only charged me labour and parts to do the repair, nothing to get the door open.
    I was told that it took them a while to work out how to get it open, but they didn't tell me how they did it.
