Audi A4 B5 aftermarket headlight pictures
CJDONNY Mar 16, 2010
  1. CJDONNY
    CJDONNY Member
    65
    Hi can anyone post up some pictures of a silver A4 B5 with aftermarket lights?
    halo in chrome and black or any other types
    can you fit the B6 lights on the B5?
    any pics would be great thanks
  2. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Ref B6 lights onto a B5...no you can't. I have Halo lights on mine but its a Santorin blue car. Heres a pic of it anyway...........
    What lights have you got on yours at the moment dude?
  3. CJDONNY
    CJDONNY Member
    65
    thanks for pic
    the lights are standard,the car is standard :)
    just got it as a ride for work,but wanting to tidy it up starting with alloys lights ect
  4. Oranoco
    Oranoco Well-Known Member
    3,998
    408
    The only lights I would look to put on are standard facelift lights if you've not got them already.
  5. CJDONNY
    CJDONNY Member
    65
    WHAT DO THEY LOOK LIKE?
    (thanks for reply)
  6. a4-rob
    a4-rob Member
    54
    they look like this fella:
    one piece lamp instead of the lamp and indicator set up you have, looks much cleaner imo
  7. CJDONNY
    CJDONNY Member
    65
    nice, there a lot better anyone got a link to were i can order them?
  8. CJDONNY
    CJDONNY Member
    65
  9. Nez
    Nez Member
    598
    Ebay :)
  10. aragorn
    18,612
    872
    you need the wiring plugs too, as they're different.
  11. CJDONNY
    CJDONNY Member
    65
    :sadlike: what of the car they come from or that come with the lights?
    can you buy the plugs??
    any help would be great thanks
  12. bad-vw-boy
    bad-vw-boy Member
    72
    can you fit xennons to these as i need som,e facelift ones for my s4
  13. aragorn
    18,612
    872
    CJDonny: mid 1999 to 2001 model A4 B5's
    Just get the plugs from the breakers, but you can buy them if your stuck.
    bad-vw-boy: You can fit one of those crappy HID conversion kits to them i guess, but i'd see that as a bit of a downgrade to be honest...
  14. slepy
    slepy Extremely smart and handsome person. VCDS Map User
    2,116
    356
    in what way it is a downgrade? Besides that it should have self levelling and washers to be legal.
    Still loads of people with B6 go with HID's thru MOT without a problem. And please don't tell me that visibility isn't better...
    BTW. I don't have HID's any more. But have different reason for that.
  15. voteforpedro
    voteforpedro Member
    632
    You could also wire the existing loom directly into the wiring inside the headlight, bypassing the plug on the rear. Would require drilling a hole in the plastic cover on the rear and would be a PITA to remove the headlights, though.
    I got mine from eBay for a fiver - bargain. You may be able to buy them from Audi. I got a pair for my foglights on my Golf direct from VW and they only cost about a tenner for both.
  16. voteforpedro
    voteforpedro Member
    632
  17. CJDONNY
    CJDONNY Member
    65
    cheers:icon_thumright:
    i was looking at these and a HID kit as i have one on the Bora
  18. a4-rob
    a4-rob Member
    54
    i have hid conversion on mine and they work fine and passed every mot i have had.
  19. CJDONNY
    CJDONNY Member
    65
    can anyone tell me how you remove them?:confused:
  20. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    they only check for headlight aim, not whether they are HIDs. we have been down this road before, to be 100% legal they need to have automatic adjustment and have washer jets to keep them clean due to the intensity of the light.
  21. jcb
    jcb Active Member
    4,132
    13
    I have HID's as well, much nicer.
    to remove you need a 6 point bit (8mm?) two on top front and one on a extension down through the wing at the outside edge.
    becareful not too but the mount at the lower front inside edge.
  22. CJDONNY
    CJDONNY Member
    65
    i notice on these Halo black aftermarket lights it says "no HID" has people still fitted them? guess its due to them being plastic and not glass??? and if the lights were on for a long time would damage the headlight unnit?
  23. jcb
    jcb Active Member
    4,132
    13
    facelift lights are plastic anyway and HID's urn cooler than Halogens so that can't be it
  24. CJDONNY
    CJDONNY Member
    65
    well i have aftermarket halos on my Bora and they are plastic with HID kit fitted while im thinking about it,so seems strange as i thought HID kits were for these projector type headlights anyway
    you say they run cooler? but on my Bora they do seem hot to touch,maybe no hotter than std headlights though
  25. CJDONNY
    CJDONNY Member
    65
    fitted the aftermarket lights this morning all is good apart from,how do you get the screw/bolt back in the bottom inside wing as before the side light came out seperate to undow it now its just one unit?
    also how to you wire up the halos to work:redface:
    Headlights fitted
    just need to work out how to wire up the Halos
  26. CJDONNY
    CJDONNY Member
    65
    Got the face lift lights fitted now after all that,the adapters cost me more than the lights :)
    if anyone wants some halo lights let me know (with/without HID kit)
  27. aragorn
    18,612
    872
    adapters?
    The harness plugs are only a few quid from audi.
  28. tangerinedream
    tangerinedream Member
    249
    + 1 to standard facelift lights with xenons, go through mot's unless there amazingly strict :)
  29. mike-a
    mike-a Member
    103
    Aragorn,there's a guy from Germany selling adaptor harnesses on eBay so you don't have to do any cutting/soldering to fit facelift lights to nonfacelift cars.£50 a pop mind! Wouldn't mind the part number for the nonfacelift sockets as I've already got a set of facelift plugs.
  30. mike-a
    mike-a Member
    103
  31. aragorn
    18,612
    872
    for 50quid i'd be cracking out the solder!
    If anyones wanting a set of facelift headlamps, i have a set available including the adjustment motors and with all mounting points intact, looking for £100.
  32. Ardz83
    Ardz83 Member
    118
    How much for the halo's cjdonny?
  33. Foxmeister
    Foxmeister Fired Up!
    1,785
    No offence Donny, but i'd go with Kev's facelifts he's offering, better looking lights!
  34. CJDONNY
    CJDONNY Member
    65
    Thats what i have fitted now mate (facelift) but they only cost me £30 :) but ill addmit i paid £50 for the adapters!
    im after £70 for the Halos posted or £90 inc HID kit
