audi a4 avant (wheel size and lowering)
Neil Conlay Sep 18, 2011
  1. Neil Conlay
    Neil Conlay New Member
    20
    hi, ive just bought an audi a4 avant tdi 130, i had so many cars over the past few years and i've always wanted one of these, so here i am, anyway, its not the sport model but it is fitted with the sport wheels, i was wanting to fit 19'' wheels to it but as its not a performance car as such i dont want to shell out on coilovers, can i fit the 19'' wheels and just lower it on springs? if so what drop could i get away with? any help would be much appreciated as this is my first audi, thank you
  2. Neil Conlay
    20
    i've had a quick look around your site and ive found that the se model sits higher than the sport so i should be able to lower it a bit more, and 235/40/19 should fit fine with say a 40mm drop, perhaps more.
  3. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    How many miles on the car? If the shocks have done big mile's you should also replace the shocks.. 25-30mm drop is good on a SE. 19's will look fine if low enough.
  4. Neil Conlay
    20
    its just about to touch 93,000 miles, it seems to of had a good life, so do you recommend just replacing the springs and shocks then? any recommendations?
  5. CMD
    3,015
    17
    If it was me i would replace the shock's and springs Yes
  6. quattrojames
    14,050
    574
    I lowered my SE on Eibach springs a couple of weeks ago, they gave a 30mm drop over standard SE ride height and transformed it. I only swapped the springs, will save the shocks for another day, no negative's yet, although it is of course early days.
  7. matttrs
    matttrs Member
    163
    I would consider getting sport shocks too or used sport shocks off ebay with eibach springs. the sports shocks are shorter and should work better with lower springs. you can change the front from b6 to B5 perches also and will go 15mm lower automatically
  8. Paul @ Unit 9 Remaps
    Paul @ Unit 9 Remaps Site Sponsor Site Sponsor
    2,035
    131
    im going with these on my 3.0 quattro sport was unsure on drop too, you got a pic what it sits like :)
  9. quattrojames
    14,050
    574
  10. Paul @ Unit 9 Remaps
    2,035
    131
    hmm nice. think for the wheels i have i need another 10mm
  11. quattrojames
    14,050
    574
    They'll probably settle a bit more still.
  12. Töm
    Töm Member
    45
    you can go low on 19's easy enough just got to get the right et and tyre size. I'm running 19x9 Bentley wheel on my Avant with a 225/35 19 tyre and i'm pretty low
    S4Paul likes this.
  13. Quattro180
    Quattro180 Member
    99
    Hi Quattrojames
    Can you give me a link to the springs, I have a se avant 2wd and would like the same look. Cheers
  14. quattrojames
    14,050
    574
    I bought mine from DPM, there's no point me linking you to them as mine will be different as yours is fwd. This is the site though:
    DPM Performance Online Store
  15. Quattro180
    Quattro180 Member
    99
    Sweet, cheers
  16. wafers
    wafers Member
    50
    Whilst your thinking about springs, would it not be better to fit coilovers, so you can tweak the height according to your preference once fitted? That's what I'm considering for my Avant 130 TDI SE.
  17. Quattro180
    Quattro180 Member
    99
    I am on a budget !!! Would be nice tho
  18. quattrojames
    14,050
    574
    The Eibachs are great. £180 plus £100 to fit, and the car is transformed.
  19. Olly A4
    Olly A4 New Member
    15
    I got some cheap coilovers off of ebay. decent price £170ish. they feel fine the damping is only 30% increased thou. I'm on 18s thou.
  20. Quattro180
    Quattro180 Member
    99
    Just got a set of s-line standard shocks & springs for £100 only covered 50k, BARGAIN......just got to fit them now!!
