Audi A4 Avant "Big Install"
Amir May 10, 2010
  1. Amir
    Amir Member
    74
    Hey.. if you have followed my previous posts you will have seen me talking about weight issues as I had a sound install on it's way so here it is just lots of pictures to keep you busy for a few minutes :).
  2. Amir
    Amir Member
    74
  3. Amir
    Amir Member
    74
  4. Amir
    Amir Member
    74
  5. Amir
    Amir Member
    74
  6. Amir
    Amir Member
    74
    PD Score = 146.7dB
    Peak = 148.1dB @ 39Hz
    40Hz = 148.0dB
    33Hz = 147.7dB
    25Hz = 146.3dB
    20Hz = 143.7dB
    dB Drag
    148.3dB @ 43Hz
    Scores taken with standard alternator and subs were stiff! Suspect this will break a 149-150db ;)
    Now pictures to follow of the alternator install :)
  7. Amir
    Amir Member
    74
    had to trim the rear corner of the engine cover to make it fit and not chafe the cables
    you can just about see the big 3 earth cable on the top bolt hole, can't get much better than bolted to the alts chassis me thinks
    over 260 amps at 2krpm, 170ish on idle, not bad for a 210a unit :)
    still drops to 13v but with upwards of 300a draw (500-600 max amps) its not doing bad and the diesel doesn't flinch
  8. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Bet it's pretty quiet :rolleyes:
    Nice install, why are the subs pointing up as opposed to facing in the car out of interest?
  9. Amir
    Amir Member
    74
    Not enough room, then you want back seats taking out and it's called a "Wall"
  10. Broken Byzan
    13,235
    464
    The subs can in theory face any direction as bass can travel any direction IIRC
    I am glad to see the big 3 still being used.
  11. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Where the hells Fido going to sit now?:laugh:
  12. Fahim
    Fahim Member
    278
    Hi,
    your subs look amazing and must sound very nice!
    I am quite envious, coming from two shitty evo cbr 12's in my A3 to nothing in my A4 avant.
    I was wondering, if i was to get something along those lines in my Audi A4 Avant, how much would a audio shop charge? Are we talking over £1,000?
    Is there any easy ''Clip on'' ''Clip off'' system used so the subs can be removed within a minute rather than tirelessly unscrewing each wire one by one etc as this is a problem i had in the A3, and that only had 3 wires i think. Live, Ground and RC..plus the two RCA's or whatever they are called!
    Sorry for thee lack of knowledge. I await your response! :)
  13. scott b
    scott b Active Member VCDS Map User
    1,254
    to disconect the wires quickly, live and earth then i would recomend an anderson conector, its what the rac/aa have on there van that they use for jump starting other cars from so more than up to the job, as for the remote wire, a simple push on splade will do the job
    anderson connector:
    http://shop.ebay.co.uk/?_from=R40&_...=anderson+connector&_sacat=See-All-Categories
    fair does thats an impresive install, you using it for sound offs / spl compertitions or just to annoy next door?
