Audi A4 Auto - Help with DTC codes - Car going in Limp mode
Winchmore May 27, 2012
  1. Winchmore
    Winchmore Member
    35
    Car goes in Limp Mode – DTC light
    #1) 17976 x 2 -Not listed on Ross-Tech but may be re throttle
    #2) 17967/P1559/005465 - Throttle Body (J338): Fault in Basic Settings
    #3) 17972/P1564/005476 - Throttle Actuator (J338): Under-Voltage during Basic Setting
    #4) 17973/P1565/005477 - Throttle Actuator (J338): Lower Stop not Reached
    #5) 17950/P1542/005442 - Angle Sensor 1 for Throttle Actuator (G187): Implausible Signal
    #6) 17579/P1171/004465 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
    17967/P1559/005465 - Ross-Tech Wiki
    17972/P1564/005476 - Ross-Tech Wiki
    17973/P1565/005477 - Ross-Tech Wiki
    17950/P1542/005442 - Ross-Tech Wiki
    17579/P1171/004465 - Ross-Tech Wiki
    Capacitance Discharge (disconnecting the battery and shorting
    the terminals together) may help with 17976 not sure about the rest
    Need help - please advise
    New to the forum :)
    Sheffield S8
  2. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    25,760
    8,834
    Welcome to ASN. One of the guys should be along shortly. Enjoy the forum. Have a :readit:through information available in threads.
  3. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,912
    164
    Looks as though your throttle potentiometer has failed. could be a simple fix (go to measuring blocks, enter 060, then click on "basic settings") to run the throttle alignment, or the throttle may be genuinely faulty.
  4. marty.h
    marty.h Member
    124
    Sounds like it needs a good clean out and the Adaptation re-done if the above does not sort it worth trying that before you go buying a new one.
    Did you try clearing the codes and see what ones return ?
  5. Winchmore
    Winchmore Member
    35
    Many Thanks !
    Going to get local garage to clean and reset.
    Will also get the spark plugs changed...not done for a long while. Which ones NGK or Bosch ....model? - V6 2.4 Auto engine
    "Did you try clearing the codes and see what ones return " no will alos give it a go
  6. aragorn
    17,960
    702
    Check the wiring plug for corrosion.
    Mine had fault codes like that and there was some crust on the pins on the throttle body, i sprayed in some WD40 and plugged/unplugged it many times and that sorted it.
