audi a4 aerial signal amplifier 2002
markk320 Apr 30, 2013
  1. markk320
    markk320 New Member
    hi i'm new to the forum so bare with me if this has been asked before. Can anybody tell me how to fit a aerial signal amplifier as i have just brought one from ebay. I was getting no am reception and dodgy fm reception. Is this easy to fit.
    thanks
    Mark
  2. mattyb6
    mattyb6 Active Member
    977
    75
    Hi mate welcome to the forum.
    is yours a saloon or avant?
    if its a saloon, if you look at the top of the rear window from inside, you will see a long piece of trim that matches the headlining.
    its as simple as pulling this off and it's on the right. (Passenger side)
    it has 3 multi plugs on ad some stubborn clips holding it in.
  3. markk320
    markk320 New Member
    Hi. Thanks for your response. Is it just a matter of unplugging the multiclips and putting the new one in?
  4. mattyb6
    977
    75
    Yeah just plug and play mate. Should take no longer than 10mins. You might need a flat head screwdriver at the most
  5. markk320
    markk320 New Member
    Nice one. Thanks for your help.
  6. Mollygoogle
    Mollygoogle Member
    262
    10
    Do you have a standard or aftermarket headunit? If it's aftermarket then it probably isnt powering the standard amplifier
  7. Az
    Az Hard slammed!
    1,044
    Why is the reception on Audi's sooooooo bad?! I have an aftermarket headunit in my car and it doesn't pick up anything on FM, it barely picks up radio 1 and that can be picked up anywhere in the country! Yet my wife's avant has the standard concert headunit in it and that's not much better.
  8. Mollygoogle
    Mollygoogle Member
    262
    10
    Reception was fantastic in my A4 with the concert fitted and is fantastic now with my Pioneer fitted. Have you definitely got the amplifier powered up?
  9. Az
    Az Hard slammed!
    1,044
    Not sure if it's powered up in mine to be honest, a conversion harness was bought for the original wiring loom and the aerial is connected as you would in a normal sinario. Have I missed something for powering the aerial amplifier?
    Dont know what would be causing my wife's concert to have such a bad reception then cos that's not been touched.....
  10. Az
    Az Hard slammed!
    1,044
    When you say amplifier are you talking about the amp that powers the sub in the boot and the rear speakers? Or is there an amplifier for the aerial? I'm assuming I've just answered my own question there cos you said there is an amplifier for the reception at the rear of the roof lining?
  11. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    There's an aerial amplifier in the boot, you MUST fit an adapter in the aerial lead that injects 12V onto the aerial lead to power that amplifier - if you haven't fitted that then your radio reception will be cr*p.
  12. Az
    Az Hard slammed!
    1,044
    An right, ok mate thanks for that. I take or these aerial adapters are available on eBay? I'll have to have a look. Cheers.
  13. PetrolDave
    1,559
    85
    Try ads like this one AUTOLEADS AERIAL BOOSTER VW VAUXHALL AUDI PC5-90 | eBay
    It's an Autoleads PC5-90 that you need, typing that gives 13 matches on eBay at the moment.
  14. Az
    Az Hard slammed!
    1,044
