audi a4 A pillar triple pod mount.
boost-addict Jun 7, 2012
  1. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    firstly sorry if im in the wrong section but here goes
    so not wanting to pay £80+ on a 3 pod mount from psi or apr i set out to make my own
    when reading along please bear in mind this will be wrapped or end up having the same fabric matching the interior,so looks arnt important, as long as the surface is smooth and transition cleanly to the trim its self. i haven't looked for the correct material, but thinking of buying a roof lining and using the fabric from that,
    this is on a a4 1999. b5.5 but can be done for any car really.
    any how
    bits i used/needed
    universal 3 pod a pillar mount was £13
    resin kit and mesh was £10, although i then found my big tin of resin and hardner!
    filler i had laying about but roughly £6 a tin
    sand paper, again i had this laying about buy roughly £3 for 5 sheets
    fabric, well not sure, but you could say the price of the roof lining from same car with same colour trim
    so roughly £32 excluding fabric or wrap/plasticoat spray paint
    starting with the a pillar its self, taken the fabric off, and cut down both sides to trim it up to the width of the a pillar trim
    then (not pictured) went to the car and positioned the pods were i wanted them
    then i screwed it to the a pillar trim and went back out to the car to make sure its defently were i wanted it, also put my new oil pressure gauge and my old boost gauge in to show how itll look
    so then set about using mesh to reinforce the side, did the other side but forgot to photo
    then using resin and matting and the mesh fixed that up. little sand down to give the filler some thing to grab. im **** at resining but the screws are to be left in so this is only to reinforce the joint so the filler dosnt crack.
    then on with filler, again im no artist so although it looks ****, its isopon easy sand so im not fussed
    so thats it for the moment. want the resin and filler to cure fully so ill leave it a few hours. then sand down and see what we have,
  2. joedredd
    joedredd 2006 A6 S line 3.0tdi Quattro Avant VCDS Map User
    200
    27
    Quick question and dont mean to put a dampener on this build, but..........doesnt that restrict your viewing area and make a huge blind spot from anything coming from the right??
  3. boost-addict
    1,000
    39
    No not dampning any thing i was waiting for some feedback etc but it doesn't too much and I guess as its the nearest pillar to me I don't think it will. It measures 3 " out from the a pillar so nothing major. If such time comes the police mot guy says it illegal then I'll remove and rethink
    ive actually stripped back the filler because the hight of the screws was forcing me to use to much filler and caused problems were the pods curve round. So I've removed the screws and it holds tight. So when I get home I'll update the pics and then re skim with filler to feather both ends on to the a pillar. I remounted it in to the car and I'm still pleased with the angle and position of the pods.
    With other pods ie in scoobys etc they have the pods up the side don't they?
  4. adamroutley
    adamroutley Member
    58
    a lot of people run 3 pod A pillars. a lot of companies sell them so kudos for making your own! i love creative threads like these!!!
  5. joedredd
    200
    27
    Funny in the photo it looks a lot further then 3" hence the question, must be the angle etc. Nice to see some personal touches during builds. Keep up the good work, and pics :)
  6. boost-addict
    1,000
    39
    yer, well got it finnished and was out and about eairler and had it installed. looks good, and dosnt restrict my view much at all.
    even the top pod is just above eye level so im happy, any how that filler i put on i accedently put to much hardner and p38 easy sand turnt in to concrete lol, still only way to learn, so an hour later with a power tool got most of it off back to plastic and the resin before, so with the right amount this time! two layer later, lots of sanding ive ended up with this, which with one last little touch up of filler were the resin has broken out of the mesh in one small spot and two places were the filler has a small nick in the surface is actualy good to be painted,
    i may even try to get the colour matched to the fabric or just spray it matte black and then once i have the correct fabric hand it over to a trimmer to do it properly as i know its something ill mess up!
    [​IMG]if i get time tomorrow ill get some filler primer for plastic and give it its first coats and build up a nice 4/5 thin layers. rub back with the finest wet and dry and then few coats of matte black, unless i can get a grey thats nearly the same. not sure yet
  7. boost-addict
    1,000
    39
    well just put some plastic primer on, three coats wet on wet, then going to rub down a little and spray with filler primer, main problem i have is ive missed 2 little areas were theres remains of the fabric, almost looks like carpet tufts
    so ill wait for the paint to harden and hopefully the paint will allow me to rub down the material left behind, also the paint has highlighted a few little dimples i missed so will fill were ever is needed and give another coat
