Anybody got any ideas about poor starting & rough idling? Power is ok . also poor fuel consumption -Had new clutch & cam - just the same. Running out of ideas & get cheeses off - Thanks Quinndog.
My 130 TDi had similar problems when I bought it although not the rough idling. When I scanned it it also had no fault codes for the engine.
I changed the MAF anyway as I know they get worse with age and with the new one fitted I got loads more response and a bit more power but no real change to mpg.
Next was the coolant temp sensor which made no difference at all.
After that I changed the thermostat as over the winter it was really struggling to get to and hold at 90 degrees. Doing that instantly gave me about 5mpg increase and the car warms up within 5-10 mins of driving now.
Still never solved the occasional longer cranking times when starting though. Main thing I guess though is it always starts!!
