Audi A4 1.8T saloon thinking of Breaking
K7ERG Apr 6, 2008
  1. K7ERG
    K7ERG Member
    372
    All has to go!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  2. Lee Goodall
    Lee Goodall Active Member
    2,279
    Sent you a PM ages ago mate but got no reply?
  3. K7ERG
    K7ERG Member
    372
    PMs replied
  4. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    i would have the front bumper off you in a second if a had money.
  5. K7ERG
    K7ERG Member
    372
    #66 September 7th, 2008
    K7ERG
    2nd Gear Join Date: Aug 2003
    Large parts will need to be collected)
    Postage available at cost.
    Not sure what alot of these parts cost so open to sensible offers.
    Front bumper RS4 some damage but can be repaired. £100
    Brake servo £30
    Rear Lights £15 each
    Exhaust turbo back 2.5" system £200
    Indicator stalk left £10
    Indicator stalk right £20
    Gearbox £100 127000miles
    Driveshafts £35 each
    Engine loom Spare 1.8T £30
    Fuel tank with pump £50
    Warning triangle £5
    Switches
    Electric sunroof motor and switches £50
    Window wiper motor £40
    Mirrors £10each
    Central locking pump (1 air connection type) £60
    Relays
    Engine parts (covered 127000miles)
    AEB cylinder head £200
    ECU £40
    Intercooler £30
    Pipe work (boost) £20
    Throttle body £50
    Starter £40
    Coils £10each
    Egine Loom £30
    ABS pump £75
    Alternator £40
    inlet manifold £50 AEB type Polished top
    injectors with fuel rail and regulator £60
    airbox with Maf £40
  6. K7ERG
    K7ERG Member
    372
    Brake servo £30
    Gearbox £80 127000miles
    Driveshafts £25 each
    Warning triangle £5
    Switches
    Mirrors £10each
    Central locking pump (1 air connection type) £40
    Relays
    AEB cylinder head £150
    ECU £30
    Intercooler £20
    Pipe work (boost) £15
    Throttle body £40
    Starter £30
    Coils £10each
    Engine Loom £30
    ABS pump £50
    Alternator £40
    injectors with fuel rail and regulator £50
    airbox with Maf £40
  7. sam80quattro
    sam80quattro Member
    146
    hi many plugs has the ecu got? if its 2 i'll have the loom and ecu
  8. Foxmeister
    Foxmeister Fired Up!
    1,785
    Do you have the grilles available for the RS4 bumper???
  9. aragorn
    18,542
    865
    You've had this stuff kicking around for quite a while, cant you shift it?
    Tried ebay?
  10. K7ERG
    K7ERG Member
    372
    Yep i sure have. I will try ebay next week as i have URS4 and URS6 parts for sale as well. Might put the URS4 leather up in the interior section on this fourm as its mint and getting rare now. I have 18" wheels also for sale. New and old style RS4 wheels.
    Craig
  11. my96A4Turbo
    my96A4Turbo New Member
    have you got the fogs and grills for the bumper mate?:icon_thumright:....
  12. K7ERG
    K7ERG Member
    372
    No grills but headlight washers are there. Not been modified to fit A4. still standard RS4 size.
    Craig
  13. K7ERG
    K7ERG Member
    372
    Front bumper RS4 some damage but can be repaired.No grills but has headlight washers £100
    Brake servo £30
    Gearbox (FWD) £80 127000miles
    Driveshafts £20 each
    Warning triangle £5
    Switches
    Mirrors £10each
    Relays
    ECU £30
    Intercooler £20
    Throttle body £40
    Starter £30
    Coils £10each
    Engine Loom £30
    ABS pump £50
    Alternator £40
    airbox with Maf £40
  14. K7ERG
    K7ERG Member
    372
    Parts still for sale
  15. jcb
    jcb Active Member
    4,132
    13
    prices are a bit steep IMO.
    I might be interested in the fule rail and assembly (you can keep the injectors) but they are not worth a great deal, £15 including postage?
    do you have the bonnet release assembly still?
    How about the flat plastic gearstick surround?
  16. sam80quattro
    sam80quattro Member
    146
    :readit:
  17. K7ERG
    K7ERG Member
    372
    AAN head (some cracks around spark plugs) £100
    Inlet manifold £100
    Throttle body £80
    coil cover £30
    Coil cover (powdercoated red with polished lettering) £60
    Rocker cover £40
    Rocker cover (powdercoated met black) £60
    Standard AAN rods £500
    Pistons AAN £250
    AAN sump £50
    Auto box £100
    Rear diff from URS4 £120
    Rear diff from URS6 £120
    Gearbox manual 6 speed £350
    AAN injectors £50
    Exhaust manifold KKK26 fitment (covered 250miles) £50
    AEL bottom end £250
    HP2 struts £200
    UFO struts with calipers and discs £80
    UFO struts £30
    UFO discs used £20
    Bilstein suspension £200
    Intercooler 2.5" inlet/outlet (covered 250miles) £100
    URS6 airbox £40
    Alternator £60
    Alternator £60
    Starter £50
    Starter £50
    Powersteering pump £50
    ABS module URS4 £80
    ABS module URS6 £80
    Aircon pump £80
    Aircon pump £80
    Standard FPR £30
    Uprated intank fuel pump £40 never used.
    Standard wastegate £80
    standard wastegate No spring £70
    Custom 3" system with downpipe, screamer pipe to fit GT3071R and tubular manifold £400
    AAN S4 wiring loom £150
    AAN S6 wiring loom £150
    360mm x 34 mm Discs EBC standard replacements (never used) £100
    Porsche 4 pot caliper rear caliper red £50
    18" RS4 rep new style wheels with good tyres cant remember make 225/40/18 £300
    Climate control unit £50
    climate control unit £50
    Steering wheel no airbag from 1992 model £100
    Clocks URS4 with ABS control £75
    Clocks URS6 £75
    Clocks URS6 Auto £75
    Avant parcel shelf £40
    URS4 Doors Avant 4 off £50each
    URS6 Doors Avant 7 off £50each
    URS6 bonnet with grill £75
    Tail lights URS4 £25each
    Tail lights URS6 £25each
    Tail gate with out centre piece £50
    tail gate with quattro logo on glass £70
    Side skirts £100
    Rear spoiler £80
    Head lights URS4 £25 each
    Head lights URS6 £25 each
    Indicator 4 off £10 each
    7 Seat conversion £80
    Roof bars £15 each
    Central locking pump £70
    Window wiper motor front £25
    Window wiper motor rear £20
    URS4 rear bumper £50 Still on car
    Electric sunroof switch and motor £50
    Switches and sensors also available
    Radiator £40
    Fan £30
    Fan £30
    Audi 1.8T parts
    Front bumper RS4 repaired no grills but head light washers. £100
    Custom Exhaust downpipe turbo back 2.5" system bolt onto standard fitment £300
    Warning triangle £5
    Switches
    Relays
    ECU £30
    Throttle body £40
    Starter £30
    Coils £5each
    Engine Loom £30
    ABS pump £50
    Alternator £40
    injectors with fuel rail and regulator £40
    airbox with Maf :£30
    Anything else just PM me i have 3 cars breaking now.
    All large and heavy parts collection only
    Also add postage to these prices.
    No timewasters please.
  18. jamie226bhp
    jamie226bhp Member
    468
    U can get a custom exhaust made for that price, all prices seem a bit steep, just my opinion
  19. K7ERG
    K7ERG Member
    372
    Both exhausts are custom from turbo back. As for prices I have put sensible offers will be considered. Thanks for your reply.
  20. dhracer
    dhracer New Member
    21
    Has the RS4 bumper been modded to fit a 1.8T? Interested if you could post it...
