Audi A3 Xenons Help .....
S3mad Oct 19, 2010
  1. S3mad
    S3mad Dark Knight
    946
    Hi all ,
    I know this has been asked a few times but can i fit some xenons in my standard lights with a decent kit i know some people say they blow the windscreen motor but are there any kits out there i can use ? Only reason i ask is the standard lights are shocking ....
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    they will blow it, do the xenon retrofit it will be cheaper all in all, up to you if you go hids though your funeral
  3. S3mad
    S3mad Dark Knight
    946
  4. Lewis583
    956
    91
    Well, you can. Wouldn't be road legal though due to no headlamp washer etc
  5. PH1L
    PH1L Gievf Buckets
    3,851
    40
    and the ***** beam pattern
  6. Khufu
    Khufu Well-Known Member
    5,704
    31
    I think the lack of deffuser is really the biggest issue, thats the one that will blind oncoming drivers & possibly fail an MOT. The washers will come into their own in the coming months but how often before the winter are they really needed? The levellings probably not be as dynamic as needed when going over bumps etc so as long as you adjust them to how many people are in the car etc it wont make too much of a difference. With all that said, when I fit mine, i'm doing it right.
  7. Dandle
    Dandle Member
    852
    The leveling system isnt supposed to be dynamic and active over bumps. Its there so that people don't drive around with the light shining to high, unlike halogen lighting Hid is much brighter and blinding to oncoming drivers. Like fitting HIDs into reflector headlights causing uncontrolled light scatter.
