AUDI A3 TRANSPONDER FLIP KEY FOB CIRCUIT BOARD REMOVAL
Discussion in 'A3/S3 Forum (8L Chassis)' started by DANO80, Jan 15, 2012.
  1. DANO80
    DANO80 New Member
    Nov 8, 2007
    I have recently purchased a new fob key case as the original has broken. I can remove the battery holder, battery and key from the original case but having problems removing the circuit board (I don't want to break it). There are two gold pins/screws either side that I cannot remove. Can anyone help? Some pictures below
  2. Advert Guest Advertisement
  3. Audijk
    Audijk New Member
    Jul 23, 2012
    Did you find out how to remove the PCB ? I am trying to do the same thing right now and I am having a hell of a time.
  4. BeeKay
    BeeKay Member
    Jun 18, 2012
    69
    i had the same issue , in the end i just used the old bottom half of my key u can replace the front part that u press that comes out nice and easy so it looks nice and new too
  5. Danio
    Danio AUDI-MANIACS.COM
    Aug 5, 2011
    214
    22
    Just use a good grip pliers and pull it up. There is no glue whatsoever, just sits on a plastic hole.
  6. Munch
    Munch Member
    Jun 23, 2012
    260
    23
    Nice and easy, I done mine a few weeks back. It just pops out. But don't forget to get the transponder chip out from the top of the old fob, otherwise the car won't start. I found this the hardest bit, just undo the screw on the back of the fob and you will see it, be careful as obviously this is what makes the car run
