audi a3 temperature gauge problem
stock211 Mar 13, 2014
  1. stock211
    stock211 Member
    45
    hi i recently fitted a new engine coolant temperature sensor as my gauge wasn't working. cleared the fault code with vcds lite and all was well for a week, now the gauge has stopped working again,did another scan and vcds is reading the temperature fine and isn't throwing any codes so dont think the sensor is bad.have any of you guy and gals got any idea's as what could be wrong? cheers in advance:music:
  2. <tuffty/>
    20,846
    3,686
    thermostat?... please define 'not working'
  3. stock211
    stock211 Member
    45
    worked fine for a week sitting at 90, all of a sudden needle not moving at all. but on scan temperature rising as normal ???
  4. <tuffty/>
    20,846
    3,686
    Which temperature are you logging? the CTS has two sensors... one for the ECU and one for the dash... you will need to go to the instruments module to log the sensor for the dash...
    Is the CTS an OE one? have seen GSF and ECP pattern parts fail fairly quickly in the past..
  5. stock211
    stock211 Member
    45
    the sensor i replaced is the blue four pin one, i thought 2 wires were for the ecu and the other 2 were for the gauge ?? the temperature reading on vcds were on 17 instrument >measuring blocks >group 3 i think. is this right or i'm i looking in the wrong place..bit of a newbie where vcds is concerned:uhm:
  6. <tuffty/>
    20,846
    3,686
    Blue 4 pin? is yours an AGU?
    Sounds like the right group in VCDS... if its rising to 90 and the dash needle isn't moving then sounds like the dash is faulty... not sure if something like will throw a fault code... have you check the fault codes in the instruments module?
  7. stock211
    stock211 Member
    45
    engine a AGN,thats what confusing me no fault codes in instruments..think i'll have to try another sensor.think it was a pattern part even tho it cost 15 quid...
  8. stock211
    stock211 Member
    45
    what i need to know is there a way to test the 4 pins on the sensor?with a multi meter? and if so how would i go about this
  9. <tuffty/>
    20,846
    3,686
    If the ECU is seeing temps and the instruments are seeing temps then the issue is the clocks mate
  10. stock211
    stock211 Member
    45
    thanks for the advice,would the clocks just die after fitting a new sensor,could it be a fuse or a short in the wiring just want to be sure before buying new dials:thumbsup
  11. stock211
    stock211 Member
    45
    just a quick update...with the help from youtube and a multimeter How to test a Coolant Temperature Sensor - YouTube i was able to test the ECT sensor, and found out it was bad. lesson learned fit oem parts not cheap ones from ebay. as the cheap one only lasted a week, we now have a working temperature gauge sat at 90.....very nice:think:
  12. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,803
    192
    Another way is to check output displays in instruments with vcds. not always conclusive but does diagnose a faulty needle motor
