Audi a3 tdi 2004 driver door not workin no central locking help!
chrisy t Feb 28, 2011
  1. chrisy t
    chrisy t Member
    132
    Hi guys, massive problem with my car,its doing my head in. Last night i went to lock my car and it wouldnt lock! i also noticed the whole drivers side door is not working! the electric windows arent working from that side, the electric mirrors wont work, the door wont lock electronicly, and the car wont alarm atall! when you use the fob to lock the car it locks every door but doesnt like the driver door and the hazard lights dont flash! ive checked fuses and they seem fine, its like the drivers side door has completely died! the buttons arent even illuminating on the door! Its asiff it has lost power completely to the door.
    Please can someone help!
  2. 19scotty81
    19scotty81 Push down and across !!!!!!!!!
    107
    Try giving the wires that go between the post and door a wiggle to start with, if they're not plugged in properly this kinda thing happens, it's quite unusual for everthing in the same door to just die without doing anything elsewhere on the car
  3. Sloth
    Sloth New Member
    My 20007 A3 sportback recently started having the exact same problem issue as the OP, except it is on my front passenger side door.
    I noticed that for an hour or so I had a buzzing noise coming from the door and the power window light was flickering on and off. If anyone has experienced this and/or knows what a common cause for this might be looking forward to hearing of their experiences and response.
    Thanks.
  4. Patrick_c99
    Patrick_c99 Member
    198
    Sounds like loose connections between the frame and door. Unplug clean and plug back in
  5. Sloth
    Sloth New Member
    Will get the door card off tomorrow to check it out, hope that's all it ends up being.
  6. Patrick_c99
    Patrick_c99 Member
    198
    You don't need to take door card off. It's between the two hinges connectin the door to the car
  7. Sloth
    Sloth New Member
    Ok looking at it now, can now see what you mean after pulling the rubber back, quite dark here so will check it with more light. Does it just unclip from the top ?
  8. Patrick_c99
    Patrick_c99 Member
    198
    Think it just twists off not sure
  9. Sloth
    Sloth New Member
    its a rectangular shaped plug, quite well sealed also.
    in the end it was the part in the door that I needed p/n 8PO959802H
  10. Patrick_c99
    Patrick_c99 Member
    198
    All fixed now?
  11. Sloth
    Sloth New Member
    Yes replacing the part fixed it, all back to normal. Sourced a part from a wrecked vehicle. Thanks.
  12. Scott Meldrum
    Scott Meldrum New Member
    Hi guys. Sorry for necro-posting here but I'm having these issues on my 2004 a3 1.6 sport 8 valve. I tried googling that part number but it doesn't come up with anything. Can anyone tell me what part actually is that Sloth replaced? Thanks in advance guys
  13. Sayam
    Sayam Well-Known Member VCDS Map User
    2,718
    640
    The part number is 3 posts up? Did you read the thread or is that not the one u need?
