Audi a3 starting/running problem
dca3 Mar 27, 2010
  1. dca3
    dca3 New Member
    Hi i have an AUDI A3 1.8 T SPORT QUATTRO when i went to start it it run for 3 to 4 seconds then cut out which it does every time does anyone know what the problem could be? Cambelt? Fueling problem, ECU problem?
  2. S3KO4
    S3KO4 Member
    850
    possible crank shaft sensor? you need to scan it.
  3. finesse
    finesse Active Member
    2,805
    scan to see
  4. chancer
    chancer Member
    114
    When my A4 1.8T did that it turned out to be the key (RFID Chip) it started and cut out after a few seconds. Tried the spare key and nearly fell over when it worked.
    Could be anything in reality and as said you need to run a diagnostic on it.
  5. dca3
    dca3 New Member
    Could it be anything worse than the above like cambelt or engine knackered?
  6. finesse
    2,805
  7. dca3
    dca3 New Member
    Ok will get it checked out and let you know.
  8. AudiiduA
    AudiiduA Member
    359
    Lol,, i had this on my Skoda VRS! had to have the key recoded ect! started first turn run for 2 secs then off!
