Audi A3 Sportsback 1.6TDI DPF light
ramagates May 22, 2013
  1. ramagates
    ramagates New Member
    I bought a A3 1.6 TDI (59plate) couple of weeks ago. when the car comes it came with 1/2 tank diesel. when i fill it for the first time i notice something on my dashboard. the DPF filter light comes ON when I put my keys in and it goes OFF when the engine starts.
    also some times i do here a beep sound when I start (not always), no warning lights stays once the engine starts
    any ideas
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Has it got parking sensors?
  3. ramagates
    no, its SE model
  4. percymon
    percymon Member
    156
    DPF light behaviour is correct - on with ignition, off when engine running (unless there is a fault when it will flash or illumnate permanently with the engine running)
    Beep could be the handsfree bluetooth phone kit - do you have one fitted ?
  5. ramagates
    i dodnt have a bluetooth, the dealer told i dodnt have one, its just a basic audio player.
  6. phil_w
    phil_w Active Member VCDS Map User Team Brill Red Audi A4 Audi Avant Owner Group S-line owners group
    606
    58
    My 59 plate 1.9tdi did the same beep sometimes - never worked it out and car has now gone - there was a school of thought that it might have been low battery related but never confirmed.
  7. ramagates
    thanks, is it worth to take it to a service center?
  8. phil_w
    606
    58
    If its like mine there was never any error codes logged so dealer could do nothing. That said, apart from the beep annoying me every so often, there was never any issues with the car.
  9. A3Kent
    A3Kent Well-Known Member
    1,571
    249
    Mine does the same beep from time to time, the cars been scanned with VCDS quite recently and nothing has shown up so i'm not worried about it.
  10. percymon
    percymon Member
    156
    Well i stand corrected -on my mk6 golf the dpf light came on with the ignition but on my 8p3 the dpf light doesn't come on at all.
  11. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    You are maybe thinking of the engine light - this will illuminate with ignition on and if there are no faults, it will go off when the car is started.
    The DPF light is shown in my picture below and the affect it has on mpg during a regen :(
  12. ramagates
    thanks guys
