Audi A3 SB Cluster swap with skc coding
blackcruiser Dec 24, 2009
  1. C39KER
    C39KER Audi TT MK2 With MSS Street Kit
    229
    124
    43
    NHN
    One more issue the petrol gauge is also not working...Do I have to change the sensor????
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    I'm guessing your car is pre-2004? If you read NHNs thread about fitting new white cluster you will see the wiring has changed and you may need a new pump/sender, one that uses 3 wires for the fuel sender not just 2.
  3. C39KER
    229
    124
    43
    Thanks mate
    my car is a 54 (step or oct) one....I have see NHNS thread
  4. C39KER
    229
    124
    43
    Woooooooooo Hoooooooooo it works like a dream oh yeah
    Thanks guys for support
  5. NHN
    29,352
    1,720
    £50 plus ur postage costs, its no money spinner but does take time to remove all parts, change test etc etc.
    Yeap, abs lights up as fault but doesnt show a fault, so have to change as I advised.
    Did you change your pump under rear seat?
    1 wire for sender iirc, the newer cluster needs 2 wires.
    Yes you will need new pump then if your fuel level isnt showing.
    Cool, but what about fuel level?
  6. Khufu
    5,704
    31
    Sorry, what I meant is you need a pump with a sender that uses all 3 wires within the actual pump unit as new one measures resistance on both sides of the pickup point (IE live and two 'earths'). If you dont have that type of pump you will need the new pump & extra wire to the cluster making it 2 wires in total to the cluster as NHN says/did. Dont know where diesel pump/sender 3rd wire goes to as I havent looked at wiring but on petrol it goes to the pickup module.
  7. C39KER
    229
    124
    43
    I just change the complete pump...can't be bored with all that rewiring stuff anyways my car had the up to date wires.
  8. spanishpacs
    spanishpacs New Member
    25
    Nobody can provide a detailed description on how to code the new cluster with the VAS machine yet?
    I am dying to install it in my car but I don´t want to lose another 100 euros if the guy in the Audi dealer doesn´t know how to do it.
  9. berto
    berto New Member
    25
    Hi! I was looking about A3 inmos, how to identify the types used.. and as I understand, you say it's always the same, right?
    I'm not worried about swaping instrument cluster, I would like swap engine ECU...
    I't some long to explain all, but the most important part it's I've a pre-facelift S3, and maybe I have to use a S3 facelift ECU to allow use other equipments..
    I was worried if the inmo were diferent and could have problems matching inmo of new ECU with my instrument cluster
    (something doesn't it's really standard, should be impossible for the dealer!)
    my instrument cluster shows this:
    Code:
    Sunday,22,May,2011,14:30:07:04214
    VCDS Version: Beta 11.2.0
                    Address 17: Instruments
    Control Module Part Number: 8P0 920 931 C
      Component and/or Version: KOMBIINSTR. VDO H20 0570
               Software Coding: 0037118
                Work Shop Code: WSC 06314
                          VCID: xxxxxxxxxxxx
    Advanced Identification
         Serial number: xxxxxxxxxxxxxx
         Identification: VDD-024
         Revision: D0H20004
         Date: 01.02.07
         Manufacturer number: 0765
         Test stand number: 7601
    Flash Status
         Programming Attempts: 0
         Successful Attempts: 0
         Programming Status: 00000000
         Required Conditions: 00000000
         Flash Tool Code: 00000 000 00000
         Flash Date: 01.02.07
    Misc.
         Hardware number: 8P0 920 931 C
         Lot Number:
         Type Lock:
    Car Info
         Chassis Number: WAUZZZ8Px7xxxxxxx
    VCDS Info:
           Labels: 8P0-920-xxx-17-MY7.lbl
    and here it's an instrument cluster from S3 facelift "white fis":
    Code:
    Wednesday,18,May,2011,20:05:12:04214
    Control Module Part Number: 8P0 920 932
      Component and/or Version: KOMBIINSTR. VDO H15 0820
               Software Coding: 0069128
                Work Shop Code: WSC 03328
                          VCID: xxxxxxxxxxxx
         Revision: D0H15004
         Date: 02.06.08
         Manufacturer number: 0700
    Flash Status
         Flash Date: 02.06.08
    Misc.
         Hardware number: 8P0 920 932
         Lot Number:
         Type Lock: VDD-
    Car Info
         Chassis Number: WAUZZZ8Px9xxxxxxx
    VCDS Info:
           Labels: 8P0-920-xxx-17-MY8.clb
    it's the same inmo type? both shows the same type of codes of Inmo4 challenge in ECU module
    both clusters shows "VDD-024", it's a type of inmo? I heard there are different type of inmo4
    thanks in advance!
  10. Ash187
    7,495
    744
    With the amount you have spent you may as well take a road trip up to the UK and have the people that sorted out NHN and N8. you can get your car sorted and have a nice holiday :redface:
  11. NHN
    29,352
    1,720
    Ok 1st tell us what new features are you wanting to get on the newer ecu?
    IMMO should be identical, given newer clusters have been fitted into cars that are 6yrs or so older.
  12. tee2803
    tee2803 New Member
    9
    Hi does any one know any dealer in the midlands area that can programe these clusters ????.Coventry AUDI are a waste of time. ​
  13. mqureshi1166
    mqureshi1166 New Member
    Hi nhn have also bought new 2011 s3 clock cluster and needs coding will your vagcom work for this or will i need vas5054?
    thanks
  14. mascun
    mascun New Member
    Hello, I don't know how to conect the new fuel pump. Any help?
    Thank you
  15. NHN
    29,352
    1,720
    Welcome to the forum.
    Do your research please, its been discussed number of times on various forums, so you need to search & read.
  16. mascun
    mascun New Member
    I found it, but the message is something like I have no permision to see that information.
  17. mascun
    mascun New Member
    Any help please?
