Audi A3 SB 8P Spacers...Help required...
210_MIH Oct 1, 2012
  1. 210_MIH
    210_MIH Drive it like u stole it
    108
    Hi Guys
    Please see pics below:
    http://i1256.photobucket.com/albums/ii491/Wirry-/IMG_2411_zpsa0ce9784.jpg
    http://i1256.photobucket.com/albums/ii491/Wirry-/IMG_2412_zpsa195d65a.jpg
    http://i1256.photobucket.com/albums/ii491/Wirry-/IMG_2410_zps551aa214.jpg
    http://i1256.photobucket.com/albums/ii491/Wirry-/IMG_2408_zps2c89156c.jpg
    http://i1256.photobucket.com/albums/ii491/Wirry-/IMG_2407_zps6eaedfce.jpg
    http://i1256.photobucket.com/albums/ii491/Wirry-/IMG_2409_zpsbaf53a04.jpg
    Im after a set of hubcentric spacers for my car. its lowered on Eibach Sportlines and the wheels are 7.5j as far as I know.
    Is there anyone in yorkshire who could measure it up for me and tell me what size spacers are needed and also anyone reliable who can fit them for me?
    Additionally, anything I have to watch out for when going down the spacers route?
    All help appreciated in advance.
  2. Dsport
    Dsport Active Member
    252
    82
    To start off with we need to know the offset of the wheel
  3. Chaffy
    Chaffy Not low, still slow
    58
    I would probably go for 10 or 15. Just be aware that if you space out too much while on springs, there will be alot of scratching against the inside of the fender, when driving around with a couple of friends. Thats not dangerous but its a bit irritating and to me it sounds a bit cheap, at least i felt so.
  4. moag
    moag she's no d-turbo
    821
    35
    12mm rear and 10mm front will be perfect.
    Fit them yourself! If you can remove a wheel you can fit spacers...
  5. Reload
    Reload Bird is the Word!
    367
    49
    I have 11mm all round on mine which seems okay and looks good ;)
  6. andrecc
    andrecc Member
    253
    Ive got 18" speedlines what spacers would i need. :scared2:
  7. DPM
    DPM Site Sponsor Site Sponsor
    5,010
    204
    It'll most likely be 10mm front and 12mm rear but to be sure we'd need to know wheel size, width and ET.
    Damian @ DPM Performance
    Sayam likes this.
  8. 210_MIH
    108
    HI Mate. not too sure, they are OEM BBS (either Ch or Pescaras)...
  9. 210_MIH
    108
    would you say the hubcentric spacers or the universal?
  10. DPM
    5,010
    204
    Always hubcentric when possible!
  11. adie1
    adie1 New Member
    15
    Hi Guys
    I am looking at lowering my a3 s line tdi 170 3 door. i have the 18" rotor arm replicas 18x8.0J on 225 40 18 tyres with PCD 5x12 offset 45
    C/B 66.45. Would it be ok to lower it with eibach sportlines 45-50mm ? and also what size spacers should i use on front and back for that aggressive look when lowered. Your feedback would be much appreciated.
  12. Mindak
    Mindak Active Member
    799
    130
    43
    I ran 10 front 12 rears no problem!
  13. DPM
    5,010
    204
    As above, 10mm front and 12mm rear should be fine.
    Sayam likes this.
  14. Sayam
    Sayam Well-Known Member VCDS Map User
    2,703
    631
    12mm rear would take the effective offset down to 33 on the rear. Wouldn't that rub if using 225/40/18 wheels and lowered using the Sportlines?
  15. DPM
    5,010
    204
    Should be ok, it will depend on how often you have a full car or carry luggage.
    Sayam likes this.
