Audi A3 + RNS-E + Parrot
dinothetiger Nov 28, 2009
  1. dinothetiger
    dinothetiger New Member
    12
    hi, i've recently fitted a RNS and parrot to my audi 2007 A3. It all worked, however i cant for the life of me get rid of the following errors, i have cleared them however they keep coming back?
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 Q HW: 8P0 035 192 Q
    Component: RNS-E HIGH EU H99 0660
    Revision: 07S Serial number: AUZBZ7K9967962
    Coding: 0205715
    Shop #: WSC 00144 219 99999
    4 Faults Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 46
    Mileage: 64137 km
    Time Indication: 0
    Date: 2009.11.28
    Time: 11:54:11
    Freeze Frame:
    Mileage: 64130 km
    Count: 2811
    Clock: 11:53
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 46
    Mileage: 64137 km
    Time Indication: 0
    Date: 2009.11.28
    Time: 11:54:01
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 46
    Mileage: 64137 km
    Time Indication: 0
    Date: 2009.11.28
    Time: 11:54:01
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 46
    Mileage: 64137 km
    Time Indication: 0
    Date: 2009.11.28
    Time: 11:54:11
    Can someone please help? :detective2:
  2. s8craig
    1,750
    55
    It's coded incorrectly, as you don't have an OEM phone, then the 7 should be 1
    Change 0205715 to 0205115
    The ZF fault is normal with the RNS-E retrofit, you can start adding extra bits to fix it, but it's not neccessary.
    For the speakers, change the 3rd digit to a 1
    So your final coding would be 0215115 for a non BOSE A3 with no OEM phone, but with a MFSW.
  3. NHN
    29,343
    1,719
    You may find because your previous radio had a slightly different antenna system, that your radio stations would now be weaker given its not the correct antenna system for the rns-e, to fix this is approx £200.
  4. dinothetiger
    12
    hi guys,
    thanks for your help, i've changed the coding to 0205115. i have a bose system in the car. however i now cannot get rid of the following;
    Coding: 0205115
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 56
    Mileage: 64311 km
    Time Indication: 0
    Date: 2009.11.30
    Time: 20:38:16
    Freeze Frame:
    Mileage: 64310 km
    Count: 3011
    Clock: 20:37
    02454 - Microphone Unit (in Front Roof Module) (R164)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 56
    Mileage: 64311 km
    Time Indication: 0
    Date: 2009.11.30
    Time: 20:38:01
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205115
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 56
    Mileage: 64311 km
    Time Indication: 0
    Date: 2009.11.30
    Time: 20:38:16
    Freeze Frame:
    Mileage: 64310 km
    Count: 3011
    Clock: 20:37
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 56
    Mileage: 64311 km
    Time Indication: 0
    Date: 2009.11.30
    Time: 20:38:01
    can someone please help....?
  5. s8craig
    1,750
    55
    Yes you unit is SDS enabled, lots of these annoying units around with SDS enabled. No good to you unless you fit a mic to the roof and have a MFSW. Which you have according to your coding.
    Or downgrade the RNS-E to software 0100 and the ugrade again with your NAV disk, that will clear the mic fault.
    The coding should be 0219115 for BOSE, no phone, MFSW
    The ZF fault you need to spend money on to clear.
