Audi A3 rear Wheel bearing replacement Hard job ?
Dom29 Jun 8, 2013
  1. Dom29
    Dom29 Member
    61
    9
  2. Best84
    Best84 Member
    137
    I had to replace the whole hub on mine due to the abs ring perishing. Only problem i ran into was the spline socket needed for the hub nut...just brought the VAG Laser set.
    Mine is a 53 plate and id pulled off with ease, took me about an hour tops and I am no mechanic :)
    That ebay one looks different to the one i had to get..maybe they changed em in 2005?
    Got mine from GSF cant recall the price but a lot cheaper than audi. Also did you use the 25% off code for ecp?
  3. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,760
    You might need the XZN or "triple square" bit. Google "XZN".
    Note this is not the same as multispline ;)
    As for the part, Dave at Stoke Audi ail sort you out (see Stoke Audi section of the forum).
  4. Best84
    Best84 Member
    137
    Laser Tools | 4939 | Spline Bit Set - 1/2"D 6pc
    This is the set i got, only £20 from a local tool store. I think its the M16/M18 you need. I didnt want to risk it slipping and chewing the spline...what a nightmare that would be haha
  5. Dom29
    Dom29 Member
    61
    9
    Ok cool thanks for the quick response , maybe i should have mentioned its a 2005 but its the facelift model so will it be different?
    Thanks again
