Audi A3 Rear Brake disc and pad removal
Salamanca Mar 31, 2014
  1. Salamanca
    Salamanca New Member
    Hi
    I am trying to change the rear disc and pads on my Audi A3 2.0 Sportsback 2007. The Haynes manual makes no mention of the handbrake being connected to the calliper. Assume I have to remove the nut holding handbrake to the calliper, is anyone able to advise me on whether or not I need to slack of the hand brake cable and if its easy enough to put back on afterwards? Its the spring that concerns me.
    Sandra likes this.
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,687
    10,767
    Hi, welcome to audi-sport.net. I will move this post into the a3 8p section. Have a read of the faqs thread, lots of info in there. Im sure one of the guys will be along to advise you. Enjoy the forum. :) x
  3. Salamanca
    Thanks, struggling to find my way around
  4. SmithyAG
    SmithyAG Active Member
    414
    61
    Shouldn't need to remove the handbrake cable I'd have thought. Is there not enough on it so that when you undo the caliper you can just move it out of the way? I can't remember since I last did mine, they're due for being done soon though tbf.
    Failing that, can you not remove the handbrake cable from the lug holding it in if you slacked the cable at the adjuster, as opposed to undoing the mechanism from the caliper?
  5. Salamanca
    Thanks Smithy, there is some movement but not enough, it appears to be the stiffness of the cable that prevents it and I did not want to force it and maybe brake the cable casing. Removing the cable from the lug would still give me the same issue as I cannot see a way to move the cable from the stop eye?
  6. hollows wife
    hollows wife Well-Known Member
    1,404
    164
    dont have to remove handbrake cable ,but you have to remove the brake caliper bracket multispline 14.
  7. Salamanca
    Are we talking about the bracket connecting the handbrake to the calliper re my original thread?
  8. Westy
    Westy Well-Known Member
    17,443
    1,105
    I did mine two weeks ago. You need a spline Socket as mentioned above. It's the two bolts that hold the carrier to the hub. You can then just swing the whole caliper out the way. Here's a few pics of mine that might help:
    You can see the top bolt in this pic. You'll also need a wind back tool if you don't have one.
  9. Salamanca
    Okay many thanks, waiting for wind back tool to come, will now send for spline socket....
  10. c_w
    c_w Well-Known Member
    1,168
    90
    As above the handbrake and cable do not need to be touched. After refitting, the handbrake will re-adjust itself after a few uses of the pedal and handbrake.
    As for the spline socket for the bolts, it depends what size rear discs they are; I swapped my discs without removing the large spline bolts for the caliper carrier (so basically just remove the caliper itself and the grub screw on the disc). My car is a TDI 170 with a solid 255mm rear disc. The main thing for me was using the wind back tool as it the piston is pretty stiff and not really possible to do it without the proper tool.
  11. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    3,988
    756
    The seal on the caliper the above picture does does not look in good condition, it should not be twisted like that.
    s3_sid likes this.
  12. Westy
    17,443
    1,105
    It's from the wind back tool. It's fine.
  13. B5NUT
    3,988
    756
    The caliper seal is stuck to the piston and is being twisted when you used the wind back tool, the caliper seal should be freed off from the piston before its wound back, so the seal should look like the one on shown on this image I found.
  14. c_w
    1,168
    90
    Yea that seal is definitely twisted, might not be a major issue but probably corrosion as meant it's not allowed the piston to turn when it's been wound back in. Should only be a matter of massaging it back in to straight position with your fingers nail.
  15. Salamanca
    Update. Job done, did not need to remove calliper hanger, as C-W suggested it will come off without, its looks impossible but it just comes out. Thank you all for your comments and advice, I was making an easy job difficult.
