audi a3 quattro haldex service
quattro18t Dec 1, 2012
  1. quattro18t
    quattro18t Member
    35
    hi all
    i bought a 2000 audi a3 18t quattro to use over the winter as the m3 goes nowhere in the snow,its actually in mint condition and i really like driving it,ive just give it a service and thought i might aswell do the gearbox oil,rear diff and the haldex service as i think il be keeping it.
    just have some questions as im new to the haldex system,when you drain the gearbox oil does it drain the transfer box or is it seperate?and what is the procedure for doing the service on the haldex system?last thing is the rear diff the same oil as gearbox?
    thanks in advance
  2. Nogmeister
    Nogmeister Member
    287
  3. quattro18t
    quattro18t Member
    35
    Cheers mate,does anyone no when you drain the gearbox oil and refill,does that fill the transfer box aswell and do you just fill till it comes out of the filler hole abit.
  4. Tooks
    Tooks Active Member
    753
    29
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/173516-gearbox-oil.html is a current thread that answers a lot of your questions.
    Basically though, drain the gearbox oil via the plug, and the transfer box from its plug. That should add up to about 2.5l, at least it did on my S3. I then replaced the drain plugs, and put back in 2.5l of new gearbox oil via the gearbox fill plug using some silicone tubing and a funnel. My car was on axle stands at the front, so all 2.5l went in without any running out. I replaced the fill plug, and then drove for a while so that the transfer box got the oil it needs too. That's it.
    When I change my Haldex oil, I just reverse the car onto ramps, drain the old oil, and then refill using a caulking gun on the haldex oil tube. If you find you don't have enough clearance between the gun and the ground, just bend the oil fill nozzle through 90 degrees. It will have a kink in it, but the oil is thin and will still flow through no problem. Be quick to replace the drain plug to minimise oil loss!
  5. quattro18t
    quattro18t Member
    35
    Cheers mate
  6. ANDYTQ
    ANDYTQ Well-Known Member
    1,184
    105
    What colour is it,my old one sold again recently,it was for sale on pistonheads from cheshire i think.
