AUDI A3 LED NUMBER PLATE LIGHT REPLACEMANTS
philipjmarshall Jun 20, 2010
  1. philipjmarshall
    philipjmarshall Member
    91
    HI ALL
    Any tip or link for replacement LED license plate bulbs on my new A3 Sportback and posibly LED fog lights as well to match my Bi-Xenon headlights.
    thanks
    Philip
  2. Richy_C
    Richy_C Active Member
    706
    159
    43
    there is a thread already set up for this chap.
  3. xnox202
    xnox202 Member
    193
  4. A3chase
    A3chase New Member
    Are those the same LEDs in your 2010 audi as the ones in my 2006 are fine but in my dads 2010 bring up a bulb error?!
  5. philipjmarshall
    91
    Yas thay are the same, did your dad fit replacement festoon led bulbs of complete led housing.
    ive read that if you fit just bubs you can get an error. id be grateful if you would check.
    Philip
  6. xnox202
    xnox202 Member
    193
    Apparently the 2010 models has less tolerances on the load. Even with my resistor mod on 150 ohms on both of the bulbs, I do get some light out error sometimes. If I turn off the ignition and start again, it might or might not come back.
    I didn't used the one from the eBay link I posted as I thought the thread was asking for a 2006 model. Sorry :crying:
  7. philipjmarshall
    91
    xnox202
    was the problem just license plate bulbs or was the fog lamps affected to, if not which ones did you fit??
    thanks
    Philip
  8. xnox202
    xnox202 Member
    193
    The fog lamps were alright. No relay harnesses or any CAN-BUS error code. I'm currently on order for the Load Resistor really so, I hope all turns out good after I installed that.
  9. philipjmarshall
    91
    what fogs lights did you buy - any links
    thanks
  10. xnox202
    xnox202 Member
    193
