Audi A3 interior lights question.
T-Bag Apr 29, 2010
  1. T-Bag
    T-Bag New Member
    Hi i have an Audi A3 56 Plate, and i want to change my interior lights,
    im looking LED lights, but there are so many opinions out there, unsure which ones are the best to use, the ideal features im looking for LED lights to be White, and the brightness is good/don't lose its brightness and lights that don't break easily
    anyone help?
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    check out jonny c's guide over on vagoc.co.uk
  3. gixxer600k4
    gixxer600k4 Member
    692
    have a look here http://www.ultraleds.co.uk/automotive-bulbs-c-101.html
    you should need the 40-44 mm for front and i think its around 38mm for back ones i have ones like these
    http://www.ultraleds.co.uk/42mm-leds-festoon-output-warm-white-p-1488.html front and rear and they are very good but i want ones to be brighter like these
    http://www.ultraleds.co.uk/42mm-leds-festoon-1w11w-output-cool-white-p-1461.html
    also, go for the cool white not the warm white if you are looking for the pure white look!
  4. T-Bag
    T-Bag New Member
    thanks for the urls
  5. I'mRonBurgundy?
    I'mRonBurgundy? Lets make that kitten purr...
    554
  6. vw754
    vw754 vorsprung Durch Technik
    2,324
    58
    these are great,(they will fit front) http://cgi.ebay.co.uk/Audi-LED-Numb...arts_Vehicles_CarParts_SM?hash=item439e177bcf (do the numberplate ones) but the right size you need is 42mm front and 36mm rear and 36mm for ya number plate you can just get standard festoon led's and use drl 150 ohm 2watt resistors and then you wont get the bulbs dimly lit up even when there off !
  7. gixxer600k4
    gixxer600k4 Member
    692
    to get decent light output you will need to go for a pair like the ones you ask as you will need the more LED's i think the 3 LED is the same as a 7 or 8 watt bulb. so the 9 or even 9 LED might be more what your looking for, as someone said, just get whatever bulbs you want and fit some resistors, you will only need about 2.
    http://www.oznium.com/resistors
  8. Gryphon001
    Gryphon001 Active Member
    303
    44
    Here is one for you if you are looking for downright stupidly bright domelights... sadly they don't have anything for the map lights in the back.
    http://www.oznium.com/led-domelight
    Here is what it looks like in mine.
