Audi A3 help with changing the main headlights
STEVENA3SPORTBACK Dec 11, 2013
  1. STEVENA3SPORTBACK
    STEVENA3SPORTBACK New Member
    can someone please help I have an audi A3 2009 and would like to upgrade the headlight bulbs (not LED) I removed the torque screws one at the top one nearest the wing and the one nearest the radiator, the headlight was loose but I could not remove the headlight, did I miss a torque or does the bumper have to be removed to release the headlight casing ?? all help would be greatly appreciated pictures or video links anything at all :)
  2. Ash187
    7,520
    758
    You need to remove the bumper in order to get the headlight out, once you take the front bumper off you can see the headlight bracket that the headlight sits on and then its really easy to see how it comes out
  3. STEVENA3SPORTBACK
    the bolt right in the middle of the bumper is very tight at the front of the scuttle panel where the bonnet catch is, I don't want to force it just incase it breaks. would it be a major issue if it did??
  4. Sidhu88
    Sidhu88 Active Member
    808
    76
    The light can be taken out without removing the headlight. On another note, just for the sake of clarity: First click on lights - sidelights, Second click - Dipped beam (what you always use to drive at night), Pull/push stalk - Main Beam (what you flash people with) Remember that! Edit: Why has the "return" function stopped working. I can't break up my text into paragraphs
  5. Madpete
    Madpete Member
    64
    I've just swapped out the main beam and dipped on my 8p, halogen ones for Ring Xenon Ultimas.
    The main beams are easy, ten minute job...
    The dipped are a pain in the ass...esp drivers side one. My advice is to remove or loosen the wheel arch lining so you can get your hand to the back of them. Make a really careful note of which way they come out.
    Im not particularly practical btw (im more technical) so someone else may have a better idea, but that worked for me.
  6. Sidhu88
    808
    76
    8p1 and 2 have more space to access the bulbs, there is more than enough space. 8p3 however is tight for space but its definitely still doable without removing the headlight
  7. SevenFortySeven
    SevenFortySeven New Member
    Hello everyone, new member here.Thought this thread was most relevant to my question. I'm changing both headlight units in my A3 (year 2012) for a set of chrome LED DRL units. These are halogen units with a 'tube' DRL inside each unit running completely round the casing. This is my first modification, and I was wondering if anyone here has done a similar swap out? The supplier told me they are plug-and-play direct replacements, but I'm concerned about wiring issues, warnings on my dashboard etc. Any advice would be greatly appreciated. Andy
  8. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    Link us the new light?
  9. SevenFortySeven
  10. SevenFortySeven
    Hi again, here's a picture of what the new light should look like. Hope I've uploaded the picture OK.
