Audi A3 Fault codes....any ideas people?????...
codrock
The ABS light came on whilst driving,so put the scanner on it and it came up with these codes.Also every now and then the red brakes warning light flashes??....
00287-ABS WHEEL SPEED SENSOR,REAR RIGHT-G44 NOT A PLAUSIBLE SIGNAL
00287-ABS WHEEL SPEED SENSOR,REAR RIGHT--G44 MECHANICAL MALFUNCTION.
01435-BRAKE PRESSURE SENSOR 1 - G201 ELECTRICAL PROBLEM IN CIRCUIT
Thanks in advance for any help.
Go into measuring blocks and log wheel speed of all 4 wheels. It should confirm whether the sensor is giving a reading or not.
Then, if you're handy with a spanner, swap the faulty sensor with the opposite side (if they aren't sided) (I.E. faulty osr sensor swapped with good nsr sensor). Clear codes and road test/log wheel speed again. See if fault migrates with sensor or whether it has stayed on the same side.
If it migrates = duff sensor; new one required.
If it doesn't then the fault is either abs sensor pickup/wiring/ecu.
