Audi A3 DRL xenon headlight
nezz Oct 27, 2013
  1. nezz
    nezz Member
    60
    37
    Hi all
    Looking for some info saw these on saleGENUINE Audi A3 DRL xenon headlight but comes with no ballast or bulbs. The question is how much more will i need to spent to get these fitted to my a3 58 reg facelift sportback. Thank you.
    What i have on car at the moment
  2. Ash187
    7,495
    744
    Well the D3S bulbs can be bought from shops like 'xenonhids4us.com' for about £60 (not genuine but good enough) and ballasts are around £100 a pair from eBay (you would need genuine ones). Then there is the cost of fitting, if you are not going it yourself you will need someone to do it for you.
    Where abouts are you based? Pm me for further info
  3. nezz
    nezz Member
    60
    37
    Thanks Ash pm sent.
  4. pablo
    pablo Active Member
    985
    60
    are ballasts not around 100 each?
  5. JohnE
    JohnE 2005 A3 Sport 1.6 FSI
    415
    40
    To get a proper OEM fitting you need headlamp washers and associated plumbing and wiring, a new light switch and auto levelling unit fitted to suspension as well as VAGCOM/VCDS coding - you can get them working with less but they won't be compliant with the Construction and Use regs that a factory fit is. Depends what you want.
    nezz likes this.
  6. Yolo_8p3
    Yolo_8p3 Active Member
    330
    41
    i did the whole thing what your asking about and would never do one again was a real pain
    nezz likes this.
  7. nezz
    nezz Member
    60
    37
    How was it a pain thanks for the contribution was it expensive to do as i dont have much money and what with the washers and the leveling bits what im i looking at spending on this as i want it to be legal if not then will keep the halogen ones.
    Thanks again.
  8. Camerz
    Camerz Member
    66
    10
    i bought the headlamps, ballasts and bulbs a while back. Cost me around 600-650 and when i found an audi specialist near me they quoted me 1200 for fitting. Needless to say i told them to get lost!
  9. c_w
    c_w Well-Known Member
    1,163
    87
    I fitted a D1S setup to my car, pair of ballasts with cables were £65 off ebay (OEM BMW Hella), OSRAM or Ebay special D1S bulbs £10-50.
    You just have to get a good ballast to avoid the wiper damage. So either a 2nd hand pair of OEM or known quality replacements. You will also need a wiring adaptor harness (Kufatec), perhaps £50 or so.
  10. SPARTAN91
    SPARTAN91 RED FIVE STANDING BY Regional Rep Team Silver Audi A3 TDi
    484
    165
    43
    Front bumper also needed like mine to allow the washer jets to come out of (panels under the lights)
  11. nezz
    nezz Member
    60
    37
    My car is same year as yours 58 reg facelift so do i need to change my front bumber.
  12. SPARTAN91
    484
    165
    43
    Only if you intend on fitting the washer system as the holes are needed to allow the jets to come out off
